timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 18,836
That's very odd. There must be some other common factor.I thought the same thing but disconnecting it from the inverter has always worked. Im talking from many experiences not just 1 case
If the inverter isn't properly grounded. Then it would make a difference in where the PV grounding was connected. But moving it doesn't fix the problem, it just hides it.
