I switched the PV wires to another inverter (I have 4 in parallel ) that is working fine, and suddenly got the code 19 result again. So something about this one PV string is making whatever inverter it is attached to trigger a code 19. With the wires disconnected from the inverter, but hot, a volt meter set to DC reads 302v, I did check +/- and they are not reversed. Have you ever seen such strange behavior? I also checked DC readings for the battery cables (57.4v), and AC load outputs (120v for both L1 & L2).
