Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,806
So, HyperVoc was just a gimmick name for the difference between the top of the usable range and the VOC?
The same thing that every MPPT on the market has.
Sounds like they just listed the VOC as lower than it actually was.
No gimmick, a clever design.
When > 600V is applied to PV input, the switching transistor sees Voc - Vbattery.
When the switching transistor closes, connecting inductor to input capacitor, it sees zero volts.
As soon as the transistor opens, input voltage of the inductor flies negative at ground or battery(-). The transistor now has Voc on one side, zero on the other.
I think HyperVoc means detect voltage is above max (150V, 600V, whatever), and don't switch. Then it can survive Vbattery + 150V, or +600V.
It looks to me like capacitors have to handle the higher voltage, but transistor benefits from this design.
