Willowflowage
- Feb 17, 2021
- 30
I bought 2 of these used 330watt panels.will this charge controller work ok with my 12 volt lifepo4 battery.
It's a 20 amp 12/24 volt. I'm afraid the amps could exceed the 20 amps in full sun. I bought the controller for 2 -100 watt panels wired in parallel. I will now use the 2 -330 watt panels instead. If wired in series would it then be 24 volts and ok on a 20 amp controller?
Link to controller....
HQST MPPT Solar Charge Controller 20 Amp Negative Grounded Controller with Bluetooth LCD Display, 12V/24V DC Input Solar Panel Regulator for Gel Sealed Flooded and Lithium Battery https://a.co/d/hScpHWB
