FoxtrotMichael1
Complete Protonic Reversal
Ok so I think to get the kind of power I’m looking for which really isn’t crazy, like I had said in another thread I want to operate two fridges and like one lamp and deep freeze that uses about 215kwh yearly. Have the one GoKwh 12v 100ah now attached to the Renogy 40 MPPT and my Giandel 2000w. SO if I add 4 more 100w panels outside and maybe use a GoWh 200ah that I’ve listed below I should be ok right? I mean since it’s same manufacturer it should not matter if I go parallel or series right just so long as I charge it all to 100% individually and they are all balanced I think. And so should I swap out my melts to T fuses or does anyone think I’m fine the way I am?
batteryfinds.com
![batteryfinds.com](https://batteryfinds.com/wp-content/uploads/2023/11/GoKWh-12V-200Ah-LiFePO4-Battery-Built-in-Smart-Bluetooth-LCD-Displayicon.webp)
GoKWh 12V 200Ah LiFePO4 Battery Built-in Smart Bluetooth & LCD Display - Battery Finds
GoKWh 12V 200Ah 2560Wh LiFePO4 Battery with LFP pouch cell and advanced BMS ensures 4000+ long cycle life and exceptional discharge performance. Built-in LCD display which allows you to conveniently check the real-time performance of the battery without a multimeter. Monitor battery performance...
![batteryfinds.com](https://batteryfinds.com/wp-content/uploads/2021/03/cropped-Battery-Finds-Logo-512x512-2-32x32.jpg)
