Agnostic dyslexic insomniacs lie awake at night wondering if there really is a dog.Sorry, No, just my lisdexia.
Mike C.
Currently trying to hook up the patch cord from Watts247, not having any luck with the two pin connector.Agnostic dyslexic insomniacs lie awake at night wondering if there really is a dog.
Mike C.
I have been looking at the same thing. can't find the setting for F and C. Also, my battery percentage is reading 894%.Note to self ... do not have 4/0 positive battery feed cable near uninsulated battery buss bar when stumbling around. Just about had to change shorts on that one.
It is alive.
Is there a way to correct the voltage reading? It is off by .2v.
Can the temperature readings be changed from celsius to fahrenheit?
The nhx is the one with the .2v deviation. Haven't hooked SolarAssistant to the nhx yet. It would be really nice if @mciholas comes up with a better solution.I have been looking at the same thing. can't find the setting for F and C. Also, my battery percentage is reading 894%.
I wouldn't worry about a couple of points on the voltage reading. We are talking about Solar Assistant, Right?
Do you have a preferred supplier?Now I need to source another +500' of 10gauge.
Might as well spend it before it loses more value...Only money, right?
Been finding a few good deals on ebay. The last 500' roll of 10gauge was $90 shipped. Need a couple more deals like that to finish this project.Do you have a preferred supplier?
That's a great price.Been finding a few good deals on ebay. The last 500' roll of 10gauge was $90 shipped. Need a couple more deals like that to finish this project.
With the way prices of almost everything have skyrocketed, it will not take long to spend it!
0.2 volts on 50 volts is 0.4 % error. That is pretty good given all the possible error sources in voltage measurement.Is there a way to correct the voltage reading? It is off by .2v.
I hope not.Can the temperature readings be changed from celsius to fahrenheit?
I bought six 500 foot rolls early this year from Menards at $129 with the 11% rebate to boot. Was in Menards the other day and saw THWN was $139 with 11% rebate it is $123.71.That's a great price.
Zoro has 500' for ~$140, I saw it when I was looking for 6awg earlier.
I see two steps, step 1 is the cable, step 2 is the config. I don't see two methods of connection.Here's the link SA sent. Looks like there may be two ways to hook up SA to this inverter.
It really annoys me that critical limiting values like this are not in the documentation for the unit. All you got is some verbal or email to rely on, and that's from a reseller in China and not even the manufacturer.the 10kw unit is rated for 100amp pass through.
Thanks. I'm very new to this, so I appreciate the feedback. Just trying to get a better handle on things before deciding on any purchases. This will be my first solar setup, and I have a ton to learnIt really annoys me that critical limiting values like this are not in the documentation for the unit. All you got is some verbal or email to rely on, and that's from a reseller in China and not even the manufacturer.
Also, how are you going to get 100 amps to pass through with the load terminal block seemingly limited to 8 gauge?
I feel like one shouldn't ask from more current through this inverter than it can generate itself. Going to 100 amps versus 41.7 amp rating is asking a lot. Losses go up as the square of the current, so 100 amps is almost 6 times the losses and thus 6 times the heat in the circuits.
Mike C.
I agree, the connections get hot too.I feel like one shouldn't ask from more current through this inverter than it can generate itself. Going to 100 amps versus 41.7 amp rating is asking a lot. Losses go up as the square of the current, so 100 amps is almost 6 times the losses and thus 6 times the heat in the circuits.
Mike C.
Thank you. I've looked through that a few times and couldn't find anything specific for grid pass through/bypass. However, it is clearly listed as 200a in the spec sheet for the upcoming Amensolar 12kw split phase (see attached). Frustrating that there isn't any consistency in listing specifications. The EG4 18Kpv also appears to be capable of 200a bypass, so until the very valid point about wire gauge was mentioned, I didn't see 100a bypass for the NHX-10kw as too out of line. But as I said I am a total beginner so still missing a lot. Appreciate everyone's assistance.Make that a fine strand 6 as getting a regular 19strand Southwire thhn/thwn 8gauge was a complete bear. Ferrules might help get the 6gauge to fit. 10gauge will fit in the pv inputs without issue. Give me some time, and I'll try to get 4awg in the unmounted inverter grid input. I'd do it now but we have to prepare for the really krappy weather fixing to come through our area.
Even with 6gauge connected ... what size of wire/trace is inside the inverter? I've seen nothing more than 41amps mentioned in the manual.
@jh1982 you can download the manual here nhx manual
Yeah, I saw that one. Part of the reason the NHX10 and EG4 6000XP are at the top of my list, followed by the SRNE products. The 12k Amensolar sounds good on paper, but I'd like to see some real reviews first. You sound fairly pleased with your NHX10Look up Will's video of the megarevo. Bug after bug. Not good. The strongest reasons I had for purchasing the nhx10 was Watts 'supposedly' working out any bugs with this never version and the reputation Watts247 has for customer service. He answered questions about another inverter and I had never bought a thing from his business. It is doubtful I would have taken a chance on ordering straight from China, or an unknown seller.
It's only been up and running a few days, and it's only being used to charge batteries. If these storms leave us alone, plans are to get my 80yr old pops over here this weekend to help take the old growatt down and put the other nhx in its place on the wall. Two nhx in parallel. When the ct's come in (drat, ebay just canceled the order) I'll try backfeeding to the house but zero to the grid. That's when the real test begins.Yeah, I saw that one. Part of the reason the NHX10 and EG4 6000XP are at the top of my list, followed by the SRNE products. The 12k Amensolar sounds good on paper, but I'd like to see some real reviews first. You sound fairly pleased with your NHX10
Something to consider is that the terminals appear to be just DIN rail terminals and one could, in theory, just replace any of them with something better, say ones with screw terminals instead of springs, and with larger terminals that can take 6 gauge easily. The GRID terminals are larger than the LOAD terminals, and I surmise this is because you could be drawing from the GRID to power the LOAD entirely (no panel power, no battery power) *AND* at the same time be charging the battery at a high rate. So the GRID input has to deal with more current if you do that.Make that a fine strand 6 as getting a regular 19strand Southwire thhn/thwn 8gauge was a complete bear.
To be exact, the NHX10 *is* an Amensolar N3H-X10-US. The data label on the side will say so.It appears the nhx10 is a rebadged amensolar n3h10k.
Denny Wu at Amensolar confirmed he supplies the inverters to Watts247. Whether he makes them or not is another question.The nhx I have has amensolar n3h on the sticker, although, I do not think amensolar is the manufacturer.
We shall see.The strongest reasons I had for purchasing the nhx10 was Watts 'supposedly' working out any bugs with this never version and the reputation Watts247 has for customer service. He answered questions about another inverter and I had never bought a thing from his business. It is doubtful I would have taken a chance on ordering straight from China, or an unknown seller.
