Our home is much more comfortable in summer with mini-splits than the traditional central ac system we used for 30 years until 2022. Winter is no different, if house gets cold the old system comes on and helps the mini-splits.A mini-split is more efficient, but it pigs up wall space, and doesn't vent into storage rooms and bathrooms and ... That lifestyle thing again.
How much total mini split tonnage do you have?Our home is much more comfortable in summer with mini-splits than the traditional central ac system we used for 30 years until 2022. Winter is no different, if house gets cold the old system comes on and helps the mini-splits.
With the old system, ducts in attic, when temps were in 90’s the system could not get the house cooler than 72 until 10-11 at night. With mini splits the bedrooms never get above 70 - quality of sleep no comparison whatsoever. Mini splits are very quiet compared to the roar of the compressor in old system and rushing wind out the vents.
4 tons. We have one son left at home. One of the 4 bedrooms is uncooled. We don’t use it and it’s on north side of house, if someone slept in it I’d install another MrCool.How much total mini split tonnage do you have?
That's why I did a conditioned attic so all the duct work is in the insulated space.The problem with most central air is entirely lack of zone control and duct work placed into horrifically hot areas. Just because it's easy to run duct work in an attic, doesn't mean that is where it should be.![]()
Wow. Nice. have 5 tons and a smaller house than yours but i'm not convinced my HVAC units can maintain 70 degrees. I keep my house at 78 though and if it gets below 77 during the day I start feeling cold4 tons. We have one son left at home. One of the 4 bedrooms is uncooled. We don’t use it and it’s on north side of house, if someone slept in it I’d install another MrCool.
Our original systems is a 3 ton and a 4 ton. Mini splits kick its butt hands down.
Right. We even doubled the 1/2 fiberglass insulation to not much difference in the end. Might need 6" around each pipe to make a difference.The problem with most central air is entirely lack of zone control and duct work placed into horrifically hot areas. Just because it's easy to run duct work in an attic, doesn't mean that is where it should be.![]()
16 months for house system, basically off grid as the only grid power (25 Kwh) used was last winter with 3 weeks of limited sun available and battery bank depleted.just curious what everyone's peak demand is and how much it would take to be completely on inverter.
for me the highest demand I've ever had was 19.8kw so I can confidently say that I could run my whole house "off-grid" with 20kw of inverting power.
I install them frequently…I would love to have an inverter based, throttling, central air unit, if combined with a zoned controlled blower with ducts. Talk about living the dream!
For the blue smurfs:What's your average consumption in this graph? Looks like a lot!
As noted this is the goal not there yet but its for :What on earth do you have that requires 500A+ service? (125KW = 240v * 500A (single phase)).
Attic fans are nice (had one growing up), but a few caveats....One thing I never see mentioned on here that is an alternative to air conditioning (I personally worship my ac units every night so its against my religion personally) are attic fans. My grandparents house for instance has one. Its amazing how well it actually cools the house at night. After the sun has been down for an hour or at least right before bed time my grandfather would flip the thing on and this giant metal louvered panel in the ceiling at the center of the house would open and it would draw a ton of air up into the ceiling there forcing air into any open window in the house. The air coming in felt a bunch cooler than the outside temperature too. I'm sure it uses a fair amount of power moving the massive fan in there but it can't be as bad as the central air running or window units.
Just thought I would mention it since I hadn't seen it talked about on here. Thing really does work.
The only part of that I remember dealing with was the humidity part. It didn't feel humid as much as the bed sheets felt a little damp at times. It moved allot of air which probably helped keep you from noticing it as much.Attic fans are nice (had one growing up), but a few caveats....
1) your attic needs good venting. Large eave vents work well, not sure how well little ridge vents would.
2) you may suck in a LOT of little gnats through the screens. Most likely won't survive getting yanked through like that but be prepared to clean up in the morning under your windows lol.
3) if it stays warm and muggy overnight like it did here last night, well, you're outta luck for any relief!
So your not offing inmates from limestone then?As noted this is the goal not there yet but its for :
12 charge controllers and 36 crypto miners minimum.
They had me interested until you said thisAttic fans are nice (had one growing up), but a few caveats....
Insects here are a major issue we have to sweep literal tonnage off the patio some mornings.1) your attic needs good venting. Large eave vents work well, not sure how well little ridge vents would.
That's like 7 months of the year3) if it stays warm and muggy overnight like it did here last night, well, you're outta luck for any relief!
Yes. Maybe we need to differentiate between "attic fans" that cool the attic and "whole house fans" that cool the house. "a whole house" fan can bring cool night time air into the house. "Attic fan" only vent hot attic air to the outside as I understand it. Swamp coolers are also good and use a lot less power. Can lower incoming air temp by 30F. Helps to be in an area with low humidity.One thing I never see mentioned on here that is an alternative to air conditioning (I personally worship my ac units every night so its against my religion personally) are attic fans. My grandparents house for instance has one. Its amazing how well it actually cools the house at night. After the sun has been down for an hour or at least right before bed time my grandfather would flip the thing on and this giant metal louvered panel in the ceiling at the center of the house would open and it would draw a ton of air up into the ceiling there forcing air into any open window in the house. The air coming in felt a bunch cooler than the outside temperature too. I'm sure it uses a fair amount of power moving the massive fan in there but it can't be as bad as the central air running or window units.
I’m surprised at that.20 kW of panels, 60 kWh of batteries and now that we've hit A/C season it's not keeping up. It doesn't help that it's hitting 90 every day (with 75 dew point) but cloudy with thunderstorms that keep popping up. Yesterday we got less than an hour of sun.
I have a whole house fan. It does very well in spring and fall.One thing I never see mentioned on here that is an alternative to air conditioning (I personally worship my ac units every night so its against my religion personally) are attic fans. My grandparents house for instance has one. Its amazing how well it actually cools the house at night. After the sun has been down for an hour or at least right before bed time my grandfather would flip the thing on and this giant metal louvered panel in the ceiling at the center of the house would open and it would draw a ton of air up into the ceiling there forcing air into any open window in the house. The air coming in felt a bunch cooler than the outside temperature too. I'm sure it uses a fair amount of power moving the massive fan in there but it can't be as bad as the central air running or window units.
Actual apples to apples comparison 40c , the xw pro is 6000w at 40c
