Thank you Gary. It opens new doors.
Anyway I think I know in the meantime why we have not seen any good amps yet and with the little we did see things started snapping at around 27 watts.
It is because I am still a moron
I think that is what it is
You see that I 'forgot' 'again' that having smaller wires on the AC high voltage side is much more forgiving than on the low (+40VDC is lethal. Don't be a moron like me) DC voltage side.
Yet how did I wire things from the rectifier to the battery with the shunt in between? hahah yes you have guessed is. Moronically
So even though the custom t2.5 belt is in I no longer really believe we actually need to go even more brutal than 1:11.
Why the pulley snapped is simply because there was soo much resistance in the wire going to the battery that the whole setup basically became like a bottleneck. A break of sorts.
hahah one tries braking this turbine from close to the center
it is near impossible
On the outer rim it takes not too much effort. I have not seen 9KG stopping force as of yet.
next time I wire this shunt up is with the BIG wires between the load and the battery like on the schematic.
I am such a dumbass that I used the same tiny wire for all lines in the diagram at first.
(not these new tiny wires that are way more tiny then the original yellow ones.)
Now I realize that this t2.5 belt is but 20mm wide. Unless I did not read it correct it has but 0.5KW of pulling potential.
But we do not need that much to accelerate the disk. Let inertia help us out there. And having big fat disks will definitely do that.
But if a t2.5 is really needed, as opposed to a new T5 or the original T10, to get close to 322 watts of input power to the battery bank. And 0.5kw pulling potential is not enough then I will get more of the same and then stack them.
But in many ways I really do think now that the best way to test an alternator is to test it against it's intend load.
I mean these cells will give minor resistance until close to being full.
This does not mean though that I would not like to also give other points of view like that of Gary's a run. I mean why not?
