Received the SRNE ASP 10KW split phase inverter today. Similar box and packaging as the HESP 12KW I previously ordered. Box was scuffed up from shipping but the inverter is well protected inside the box (foam) and was pristine.
Also like the HESP the ASP appears well built, case is sturdy (powder coated steel, the HESP is powder coated AL). I looked inside and circuit boards, wiring, cables all look good, well marked, logically laid out.
After unboxing I hooked it up to a power supply for a quick test. Good display with lots of operating parameters displayed, the menus are fairly intuitive and settings were easy to adjust. I had it configured and operating in minutes.
In the box was parallel cables, battery lugs, mounting bolts, and wifi dongle.
So all in all fairly positive initial impressions. Time will tell but like the HESP it appears to be a solid inverter and good value.
If this one test out, I am likely to order another to have a 20KW setup. I would consider doing a bulk order to save on shipping, message me if you have an interest.
