I use mine as a preliminary check, after testing it on a known live circuit first. I still will poke with a meter or other contact tester before grabbing stuff.Throw that voltage tickler away. The only way they fail is to provide a false āno voltageā indication. They are not allowed on any of my job sites. They are killers.
Sadly wiha moved production to Vietnam before that they were extremely good tools but the quality has dropped a fair bit not to say they aren't still a pretty high standard.Made a community post on my YouTube asking people why they would spend so much for these screwdrivers. Now I have the whole collection
View attachment 230364View attachment 230365View attachment 230366
Oh wow that's good to know and very unfortunate. Darn it!! I will check out that brand next thank youSadly wiha moved production to Vietnam before that they were extremely good tools but the quality has dropped a fair bit not to say they aren't still a pretty high standard.
Not sure of the price difference in the US but I'd highly recommend trying a Wera set next the slim insulation is a god send when disassembling recessed screws and they do some fancy laser etching on the tips to make them grip a screw better.
Many service electricians end up removing a large portion of insulation on most screwdriver for recessed screws which then breaks code as far as OSHA/health & safety(doubt your that worried) so Wera is literally the only option to get the job done without getting kicked off site.
Next thing is buy some cobalt step drills is see that "Titanium" one hanging in your peg board the fluke meters likely think riff raff have moved in next door.
Just looked them up, surprisingly the full kraftform set doesn't look that expensive there it's comparable to the wiha if your ok with the interchangeable blades.Oh wow that's good to know and very unfortunate. Darn it!! I will check out that brand next thank you
They aren't killers. They are very useful tool in the hands of someone who knows how to use them.Throw that voltage tickler away. The only way they fail is to provide a false āno voltageā indication. They are not allowed on any of my job sites. They are killers.
I use mine to trace live circuits. Very helpful when working alone in the attic. I ALWAYS verify with a meter before working on a circuit, but I'm also a big chicken when it comes to electrickery.Throw that voltage tickler away. The only way they fail is to provide a false āno voltageā indication. They are not allowed on any of my job sites. They are killers.
In my industry they are not allowed (generator installations). I have nationwide experience with AHJ's, clients, and safety officers. They aren't even allowed on many sites. Read thru the comments and then reflect on what they are actually used for by the responders here. Totally useless and unsafe.They aren't killers. They are very useful tool in the hands of someone who knows how to use them.
For starters, only use it to prove power is there, not to prove power isn't there.
I don't leave home without that exact same model but 99% of my life is troubleshooting. No power button, it's always on so you don't have remember to turn it on or wonder if it's timed out and turned itself off.
I will say that I'm pretty sure tried every other model and found them be crap, so no argument there. Power buttons that require to you to push them twice or hold them down longer to get to special features only confuse things.
Good to knowThrow that voltage tickler away. The only way they fail is to provide a false āno voltageā indication. They are not allowed on any of my job sites. They are killers.
I had no idea about the connect button! Holy cow that's amazing!I'm more of a Wera guy than a Wiha guy. The insulated interchangeable shank kit is amazing. I've been using it for years.
As far as non-contact voltage testers go, I've been using Fluke for years, and I've gotten plenty of false positives, but never a false negative. I am a master electrician and usually keep mine in my pocket, and if I'm actually grabbing onto something I double check with a wiggy-type tester (for AC circuits).
Also, I've been noticing more Fluke meters popping up on youtube. If you have that clearish looking button on the clamp meter (or any others), that is the fluke connect button. Download the app, connect to the meter with bluetooth, and you can do graphing so it shows peaks and basically is a recording meter. I use one all the time for testing motors and such, absolutely love it. The range is amazing also, I can have the meter in a metal cabinet, and still connect at 50+ feet away.
I love it. Here's a screenshot of a motor i was testing while it was running last year. I always forget to take screenshots, but this will give you an idea of what you can do.I had no idea about the connect button! Holy cow that's amazing!
Yeah they are insane. I just bought an arc shield face mask yesterday. Absolutely ridiculous amount of energyWe were warned about wiggy blowing up.
Searching the topic I find:
"Didnāt blow up in my hand but saw an engineer tap it to the primary of a 4160 transformer.
Lucky it shot past his head."
Wiggy rail gun!
"480V Arc Flash"?
Looks more like "Arc Blast" if you ask me.
I thought Arc Flash was a really bad sunburn.
This one they called Arc Flash too:
The flash is the photons (you know, what this forum is about.)
The blast is the shock wave, debris, plasma (like a mini CME)
Seems like a good, safe use.
But might need something disguised so as to not run afoul of the safety rules.
