12VoltInstalls
life passes by too quickly to not live in freedom
The lingering few seconds of inductive loads may be a ‘converter problem’ but the initial drop, spike, and flutter can also happen on direct connection equivalent voltage power from a battery (bank).Inductive loads are difficult for the DC converters to handle.
An oscilloscope read of what happens when a load is applied to a line will reveal some interesting ’reactions’ to voltage when the samples per second is high and plotted on a curve. It’s the same kind of thing that burns out radios, stereos, and sonar on a boat when one turns the key engaging the starter motor; an event of high voltage occurs both when the key is engaged to ‘start’ position and then again when released from ‘start.’ The release is the more violent but shorter in duration.
I’m no EE but in this case I think that while the capacitor will work for what is basically buffering while the electronics react to the sudden load- inductive or otherwise- it is masking what happens electrically. Probably figuring out how to isolate lights vs. motor loads is the best approach even if a capacitor is used.
Like I said I’m no EE so someone with engineering background can probably confirm or destroy this information- I’ve never seen a scope reading from a power-on event with a power supply/ converter. I was just reading this and this clicked on some brain cells about inrush spikes from boat experience.
