I'm not sure which model you are looking at but scroll down to the specs (page 22) and I think you'll find what you're looking for...it appears to match the resolution of the HF one.
https://www.idealind.com/content/dam/electrical/assets/TestMeasurement/Clamp Meters/61-747_400ampclampmeter/ND 9010-1 61-747_757 Clamp Manual.pdf
More complete than the "manual", just a partial data sheet, that Lowes linked.
"DC Current (A) 40.00A 60.00A 0.01A ±(2.0%+9)"
Yes, same resolution 0.01A
600A max (another scale), good for most PV/battery systems. HF model has 1000A, 600A, 60A scales.
HF manual
"DC Current Accuracy ± 2.0% of rdg + 8D"
Almost exactly same accuracy, same percentage of reading and one fewer counts of least significant digit.
Both are about 0.1A accuracy. The 0.01A resolution is useful, e.g. when sun is off angle and you're comparing two parallel strings while they only produce about 1A each. Having resolution of 1% not 10% of the reading lets you see differences, detect if some panels degraded.
The Ideal 600A meter is $126 at Lowes:
Ideal has other meter lines as well, including 1000A but considerably more expensive.
$95 "View lower price in cart" for 400A meter drops to $90 when added to cart.
Harbor Freight 1000A is $100, 600A is $90
Amazing deals on this 1000A T-Rms Ac/Dc Clamp Meter at Harbor Freight. Quality tools & low prices.
www.harborfreight.com
Amazing deals on this 600 A T-Rms Ac/Dc Clamp Meter at Harbor Freight. Quality tools & low prices.
Quality and Quality control may vary. We expect better from Ideal and other typical brands long used in the trades.
FilterGuy bought one after I recommended it, had flaky readings until he reflowed a bad solder joint.
Shipping containers have these standardized oval cut outs at each corner of the cube. They are used to hold them to the stack on the he ship, for picking up with a crane, and holding it down to the trailer chassis. It would be much easier (and plenty strong enough) to tie into those on each...
diysolarforum.com
Harbor Freight is good about short-term return policy. They have become my go-to place for many tools.
Replacement parts are mostly unobtainium.
