But real lifepo4 don't electrolyte like on this image -
My Jk BMS has 4 holes with m3 threads which I did use for mounting. The holes are 4,5mm deep so one must pay attention to not rip the thread out the alumin(i)umThat's looking good. Very clean.
I don't know why JK does not put mounting tabs on the BMS housing. I ended up getting longer screws to replace the ones holding the case together. And then bolted 4 of them through a rack panel that is bolted into my battery cabinet. IT was a major pain to get the holes to line up, and then I also realized how NOT flat the back of the BMS housing is. So I used a few varying layers of thermal transfer tape. The stuff that is used to attach small heat sinks onto IC chips. Just one layer on the highest part, and then stacked up more layers to fill the gap as the case curved away from the plate. I was worried about heat build up, so I wanted the large aluminum plate to act as more heat sink, but it turns out it never gets more than just warm at the 80 amps my system maxes out at.
The cheap basic dumb Daly BMS units I used on my second battery bank are nearly flat, and have cast in metal mounting ears for screws. It made it so much easier to hold it where I wanted it, and just mark through the holes and drill them. Maybe JK could learn something there.
Has there been a fix for this yet ?? I have 3 older units, they are steady amps... I just fired up 3 new ones,,All same settings as old ones.. and the amps jump all over the place... What's going on...I found the same android 12 issue but app version 3.7.5 does work.
As for fluctuating current reading it also does this when charging, maybe a bit less. I really like this BMS. It would be nice to have this aspect fixed.
If this is the case, then why do BMS's 1-3 work fine ( older ones i got nearly 2 yrs ago ) and BMS's 4-6 New ones i got just a few months ago ,jump all over the place ? All 6 of my strings are parallelled.... 14S6Pintesting, thank you for the in depth description of how AC inverter draws Varying DC amps
well said!
as you mention, one way to get around this issue at a Firmware Level is to sample the Battery Current at e.g. 120hz and only report averages that cover an integer number of AC cycles (1 cycle = 1/60 second, 2 cycle = 2/60 second). It Must Be Integer Multiple Number Of Cycles.
zero crossing average would drastically reduce the fluctuation
i have had to do this before writing low level microcontroller firmware. sampling like this would completely negate that part of the fluctuation.
if BMS reads current and reports over time periods that are not 1/30th of a second precisely or 1/15th of a second precisely, this fluctuation will never go away is my theory. good luck!
oh... if running the inverter at 50hz change all the values. or to whatever frequency for locale.
excited for the 4S BMS after new years celebration![]()
This is only a guess. Maybe the sample period of the older units firmware happened to luck out with the AC line frequency where you are, so it kept sampling at about the same point of the waveform. Maybe the old firmware did a running average. But in reality, a running average, though nice to look at as it smooths out variations, can actually cause errors as it could miss short term changes in current.If this is the case, then why do BMS's 1-3 work fine ( older ones i got nearly 2 yrs ago ) and BMS's 4-6 New ones i got just a few months ago ,jump all over the place ? All 6 of my strings are parallelled.... 14S6P
Just to clarify, you do not have an inverter connected to your batteries?Maybe I'm missing something.. I am not dealing with any AC.. The batteries and BMS's aren't tied to the AC line at all..
I'm Referring to the JK BMS's I have...I have 6 of them now..
the 1st 3 are giving better % and capacity since i been bumping up the AH cap., But the Batteries are only about 75AH,, but to get a realistic reading, i had to bump up the Ah cap to 200AH... You remember i talked to you about this long ago.. Other than that, i have had no issues..
Anyway, the new ones are set up exactly the same and work fine, except for the Amp reading is just jumping all over.. The Inverter shouldn't have anything to do with the issue..and with so much DC, there shouldn't be any AC feedback..
Maybe The Kind lady that's representing the BMS on here might have some info.. But i Believe it's a firmware issue..
Hmmm, I really hope i don't have to re-orientate my batteries.. But i think I'm ok,, Mine are the BMW NMC batteries.. and represent the middle picture
Hi,, could you please have a look at my recent post and tell me if there is a solution..thanks you..In fact, we have been updating our products according to the needs of our customers. However, with the update, there will be some problems. The original customers will feel bad, but it is these needs that drive us to pursue perfection and provide customers with a better experience. We are customizing the BMS communicating with victron, GPS functions that can support other countries, and jk-b2a4s20p. These are all things that need to be completed in 2022
where and how can i flash new firmwares?
or atleast a proper bug free firmware/software that is flashable over android or pc softwareCan't. I've asked for the source code, and there is apparently some work going on to release it.
There is a programming header on the board, and it's an STM32 (or clone), so flashing it is a piece of cake. One could even create a bootloader that can flash new firmware over a uart (the existing RS485 port or CAN one) or something. Hopefully the source gets released at some point...
Thanks @upnorthandpersonal. Can you explain what the "power button accessory" is, physically? The BMS itself has a momentary contact push button on it somewhere?4) new version has a screen with power button accessory. Otherwise you need to boot it with e.g. a 9V battery
5) I believe Hankzor is doing development on the BMS, so I would buy from them right now. Previous versions available from different vendors can even have completely different firmware and don't support the power button etc.
Ohhhhh. So the switch is part of the LCD display that you have found consumes too much power. My application doesn't really need the LCD display otherwise (unattended most of the time, and no one but me would bother to look at it), so I was not planning on getting it. Sounds like I'd need to apply power to it to get it to boot up.It's this:
Hankzor JK BMS with screen and power button
Ok, update time. Finally had some time to have a look at the new BMS. The new one on the right, old one on the left. They're both 100A versions to keep the comparison easier. The port to the right of the GPS/RS485 label is the display port. As Dave Jones would say: "Don't turn it on. Take it...diysolarforum.com
(pictures at the bottom of the post). It's a screen with a button combination. The button turns the BMS on.
You should ask Hankzor to make sure. @Nami should be able to help as well - ping!
Well, I'm pretty handy with a soldering iron, and I have a lifetime supply of resistors. It sounds like if I order it today, I won't get the BMS until the end of April, at the earliest. Sounds like I should just hang loose and keep the pressure on you.....I'm working on making a schematic drawing to have just a power button. It only needs a resistor and a button instead of the screen. I'll add parts list as well. I just have not had time yet...
The turn on is only an issue if your battery is already charged up higher than 50 volts below your charging voltage. If the charger tries to power up and pulls the voltage 5 volts higher than the current battery voltage, it turns the BMS on.Sounds like I'd need to apply power to it to get it to boot up.
