Did you make those boards?Thanks. After a bit of fiddling, I got the
library imported into ESPHome and got it working that way.![]()
GitHub - FurTrader/Overkill-Solar-BMS_2-Arduino-Library: Read and Write Library for Overkill Solar BMSs
Read and Write Library for Overkill Solar BMSs. Contribute to FurTrader/Overkill-Solar-BMS_2-Arduino-Library development by creating an account on GitHub.github.com
forgot to ask, where/how did you make the boards? They look great.Thanks. After a bit of fiddling, I got the
skillz
skillz
Will you send me the EasyEDA project?
Yep, four. I'd like to play with the project, can you share it?They look good. No errors. Let me know if you want any.
Send me a PM.Yep, four. I'd like to play with the project, can you share it?
