Okay, got it. I was confused too. So I have room to extend the SOLAR array.
Now it's 8 panels in series.
I could make it 12 solar panels divided into 2 arrays.
Each solar array has 6 panels in series.
Each panel still has a Vmp of 41.50 V.
6 x 41.5 = 249 V per solar array.
The solar voltage falls still within the range for the Growatt (120VDC-430VDC).
Then connect these 2 solar arrays in parallel.
2 solar arrays of 6 panels = 12 panels in total.
12 x 450W = 5400 Watt.
100A charging at 56V = 5600W
The 12 solar panels together can then provide 5400/5600= 96% of what the Growatt is rated for.
I think this is a better match.
So far correct?
