Kind of funny seeing those two little batteries doing something that the EG4 cannot do.Posted my solution in the original thread and updated the title.
Yes, it will be a challenge to keep them equally charged. There are some additional tweeks that I can do to the wiring to help mitigate. Construct cables to equal lengths, wire directly to the bussbar, buy a Victron battery balancer... But..Kind of funny seeing those two little batteries doing something that the EG4 cannot do.
I think that this solution is going to be problematic for all the reasons you stated. I hope you can monitor the cells in those 12V packs because i think everything is going to be going all over the place.
Considering that he refused to take a measurement of how badly his wiring was sharing current, and they were wired "the worst possible way" (to quote will prowse), it's not surprising that spreading load across more cells and wires got him through the issue, whether it was a momentary DC ripple voltage overload or he's simply current/amps overloading a BMS momentarily.Kind of funny seeing those two little batteries doing something that the EG4 cannot do.
Not everybody has a clamp on DC Amp meter and his wiring while not the best should start an inverter without an a problem. Why is it that those two tiny 12 Batteries can start it up alone and yet the two 24V EG4s cannot start it?Considering that he refused to take a measurement of how badly his wiring was sharing current, and they were wired "the worst possible way" (to quote will prowse), it's not surprising that spreading load across more cells and wires got him through the issue, whether it was a momentary DC ripple voltage overload or he's simply current/amps overloading a BMS momentarily.
Watching people throw money around like that, while also refusing to understand what they're doing, is both amusing and disturbing... Yes, go buy another server rack battery without finding out whether just fixing your wiring would resolve it.
My clamp meter was pretty cheap on amazon, and it works.Not everybody has a clamp on DC Amp meter
Insisting that it's someone else's problem while doing everything wrong is clownish behavior. *honk honk*and his wiring while not the best should start an inverter without an a problem.
He didn't start it up alone, he added it as a third 24v battery, which does in fact reduce current load on the first battery BMS, even with the worst possible wiring pattern for current sharing.Why is it that those two tiny 12 Batteries can start it up alone and yet the two 24V EG4s cannot start it?
The BMS's appear to be too finicky.Not everybody has a clamp on DC Amp meter and his wiring while not the best should start an inverter without an a problem. Why is it that those two tiny 12 Batteries can start it up alone and yet the two 24V EG4s cannot start it?
"finicky" probably just means it cuts off faster when it hits the overcurrent condition, but sure.The BMS's appear to be too finicky.
Although, mine is working fine. (Knock on wood)
Yes if you have one but a lot of people don't have one as they did not think they would need it.My clamp meter was pretty cheap on amazon, and it works.
There are a lot of people on this forum with the same problem. I think we average about 2-3 posts per week of EG4 not starting the Inverter or EG4 tripping.Insisting that it's someone else's problem while doing everything wrong is clownish behavior. *honk honk*
My undersanding is that the Inverter worked just fine with that battery alone before he got the Eg4.He didn't start it up alone, he added it as a third 24v battery, which does in fact reduce current load on the first battery BMS, even with the worst possible wiring pattern for current sharing.
Your making it sound like putting BMS systems in Series is a good thing?12V lithium batteries need to be setup to be able to handle twice as much current to provide the same number of watts as a 24v battery, so there's a very good reason that two 12V batteries of this type would be expected to put more amps out than a 24V design. So it's actually using the capacity of two BMS units, not just one, to serve as this final/third 24V part of the battery.
Yes and the point is that the Spec for the EG4 when it comes to surge current seems to be very low.Also, why wouldn't the two other batteries be able to start it on their own? They might have a different allowed surge on their BMS. Different products have different specs.
Yep there is something up with it and they don't seem to know what it is or they are not telling.The BMS's appear to be too finicky.
Robby, this guy just wants a place on the internet to argue. He is not worth the time to respond to.Yes if you have one but a lot of people don't have one as they did not think they would need it.
They obviously do know. Why would they have two battery options with the exact same specs? Only difference is the bms. EG4-LL and EG4 Lifepower are identical at their core with the exception of the BMS.Yep there is something up with it and they don't seem to know what it is or they are not telling.
When the positive busbar connects to your first EG4, what is the order the wire lugs are stacked in??? Does it help if you change it so the bottom lug is the second EG4 battery, and the top lug is the busbar connect? (Not sure if that's the case already or not)Yes, it will be a challenge to keep them equally charged. There are some additional tweeks that I can do to the wiring to help mitigate. Construct cables to equal lengths, wire directly to the bussbar, buy a Victron battery balancer... But..
I don't think I will keep the "little" Big Batteries attached as a permanent solution. Most likely, I will purchase a 3rd 200AH non-EG4 Lifepower server rack battery to couple with the system.
They're simply more likely to be engineered for more current. That doesn't mean that the overall design is good.Your making it sound like putting BMS systems in Series is a good thing?
