Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
Correct. Although when using the zero export functionality the amount is very small and only happens when a load shuts off. The inverter will still shut down/sever grid connection when the grid power failsIsn’t it true that if the inverter can do grid sell, it can’t really prevent power flowing back out the grid do the control loop time and accuracy of CT readings?
