timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 18,955
How did you run the grid wires to your transfer switch?Running ground back to meter is a diffucult task for me. It requires me to pull the meter. I can not do this alone. Finding qualified help is diffucult. Sigh
I will look for help and take your advise if at all possible. Thank you for your input. It does matter.
You shouldn't have to go to the meter. Just to the existing grounding system.
