misterbubbacat
- Oct 19, 2021
- 168
I power my entire house with my single Deye 16 kW. Been online for 3 months. My monthly billing was 1100 kWh.Could be an interesting way of powering your entire house, even if not to code. Two of these Deye 16k's in parallel would have 200amps of passthrough capability just like the Solark, but with more inverting power / solar capability.
Yes, many will only need one. I guess I should have said "can power your main panel in a 200amp serviced home with 200 amps" ?I power my entire house with my single Deye 16 kW. Been online for 3 months. My monthly billing was 1100 kWh.
Do you have pictures of the installI power my entire house with my single Deye 16 kW. Been online for 3 months. My monthly billing was 1100 kWh.
He is in the Philippines using Single phase 230V which is what the Deye is made for.Do you have pictures of the install
Will do, will be posting a follow up on the options for the Neutral on the 16K. Stay tune !Misterbubbercat, I have to confess: I'm still confused about your transformer modification. Could you provide (when you have time of course) a wiring diagram that explains what exactly you did?
What is the maximum battery voltage it will allow, I can't find this either in the Manual or the datasheet. I have some LiFeP04 and LTO batteries that have max charge at 64V. Will this unit allow for that?Try this proud owner of a Sol-Ark 15K and see if you'll get a F34 error shutdown ???
House LOAD, Level 2 EV charging at full 48A and Electric cloth dryer sucking up almost 14kW.
Deye 16K - Continuous AC Power from UPS (Batteries) 16kW (16,000W) at 1/3 the price of a Sol-Ark 15K
Sol-Ark 15K - Continuous AC Power from UPS (Batteries) 12kW (12,000W)
Do you plan on creating or buying the AST 19200T-US ? ?Folks!!!!!
Just received it today.
This thing is very impressive, high quality built!!!
Can't wait to power it up. But I have to go to LA this weekend.
Will keep you guys posted.
Congrats!. Just curious, it's a brand new inverter, why do you need to crack open the chassisFolks!!!!!
You can't mix and match different type of battery. It support low voltage <= 60V, you'll need the 30K and up to support HV (High Voltage) batteries.What is the maximum battery voltage it will allow, I can't find this either in the Manual or the datasheet. I have some LiFeP04 and LTO batteries that have max charge at 64V. Will this unit allow for that?
BTW, latest model mod will now support 125A*240V ~ 30KW, is on custom order basis ! ???Do you plan on creating or buying the AST 19200T-US ? ?
