It might work and it might not. Mine did not with any method.I have one of those cheap TTL-USB for Arduino project. That might work. Then my RS485 to USB adapter is pretty much useless too. Oh well, at least I can get this thing to work without waiting for parts.
can you list exactly what you used?Feedback: I tried the Jikong RS-485 and USB-RS-485 on my JK BMS connected as they recommend and it works great. You need the correct version of RS-485. There is two of them.
Ah ok. I will just do without it. Sadly.I'm using Home Assistant, not Solar assistant, but will SA not allow you to just connect via BT using an ESP32?
I'm able to run wireless with the ESP32 connecting to the JK via BT, then uploading the data via WIFI, but I'm not sure how the SA interfaces. In my scenario, its easier than fiddling with those tiny cables, and wondering if it might be an option for SA also.
If your bms has a console port and uses pylontech protocol - check out this project which is set up to report to home assistant .Ah ok. I will just do without it. Sadly.
I'd rather not have another rasp pi. Have one already with solar assistant. Don't think jk bms support pylontech. Solar Assistant will have to do. It does provide battery info but not accurate of course.If your bms has a console port and uses pylontech protocol - check out this project which is set up to report to home assistant .
It will work with either esp32 or raspberry pi.
Pages · ClassicDIY/PylonToMQTT Wiki
Reads data from the Sage BMS console port and publishes to MQTT - Pages · ClassicDIY/PylonToMQTT Wikigithub.com
Can anyone provide a link the the ttl/usb converter that works?
These worked for me. https://www.ebay.com/itm/144314746063Can anyone provide a link the the ttl/usb converter that works?
My bad.Those are for the RS-485 module though, not when connecting to the TTL port directly without the converter.
Just what the Dr. ordered. Too bad I'll have to wait till it's out of beta.2023-03-17Beta
New features:
Corrections:
- Add support for SRNE Split-phase inverter
- Add support for Deye 20kW and larger inverter.
- Read JK BMS highest, lowest and average cell voltage.
- Experimental support for Eskom load shedding schedules under configuration -> advanced.
- Correct problem where certain settings editable in web UI is not editable via MQTT.
much more better than nothing, beta works perfect, no problemWell, that's a disappointment. I was wanting the levels for all 16 cells.
Thanks for the tip Admin. Ironically I just used the little share button you get next to the picture on Amazon as that is recommended on other forums, but I don't mind at all that each forum has its own rules to protect members and I will be more careful.@sw25481 I edited the link in your post because affiliate links are not allowed. Don't use link shorteners, etc. - just link directly without the 'ref=' etc.
