Can’t wait to try it.So I received the new usb/ttl adapter and it correcred the priblem. I no longer have issues with it not working sometimes.
I am designing the upper computer program, and then I am also contacting the factory to customize the ttl/usb converter. It may take some time. I will reply in time when I have the latest news@Nami It would be really good if you guys could provide a simple TTL/USB converter with the right connector for the BMS, so one can skip the RS-485 conversion. Or even just a connector with wires so one can attach a third party TTL/USB converter.
Hi Maintman , can you share model , link something to help buying the good one? thxSo I received the new usb/ttl adapter and it correcred the priblem. I no longer have issues with it not working sometimes.
Do you guys know if you have to restart the JK BMS or something to get it to detect the connection?
I am using this one.Hi Maintman , can you share model , link something to help buying the good one? thx
Has anyone heard from SA about getting cell voltages to show?
Dang, I just got my 4 pin JST 1.25 and hooked it up to a ESP32 which is connected to HA with https://github.com/syssi/esphome-jk-bms towards the end of my vacation, but I get no readings from the JK BMS. Do you guys know if you have to restart the JK BMS or something to get it to detect the connection? The esp32 log is just quiet. When I remove the JST from the BMS it instantly reacts. Don't really know how to search for errors and how to rule out hardware issues. I think the connections should be OK, but the cables are darn small and there could of course be something that isn't 100%...
Does that ESP32 require an arduino to work, or can you hook it up just usb to power, and then connect rx/tx and connect to it via wifi?
I don't know what the "dedicated charger switch" is - it doesn't match anything on the user interface, might be something for a dual port version or maybe the relay versoon? @Nami what is that "dedicated charger switch" (also called "Special charger switch" in the protocol pdf)?
I don't think that's the issue though. Can you monitor what's going on with the charge controller?
Me neither, it has a history and nothing has changed, ie it hasn’t turned from off to on the 7th August when it stopped charging.
Yeah, I can access the MPPT and everything looks like it should. It’s on and has no error messages.
Hm, even if it was the JK BMS not enabling any charging — the MPPT should put out power to the inverter directly, right? Daily yield should never be 0%? This rules out the JK BMS unless I am mistaken.
My cousins tried to flip on and off the MCB today between the MPPT and the inverter/battery and nothing changed. So it hasn’t tripped. I wonder if it could be faulty some other way? I don’t trust the quality of that MCB…
