Information Overload - Where do I start?:)
Modular Hippo
UK
Hi Forum:)
I am currently building a boat and instead of installing a diesel engine I am planning to use an electric motor, battery bank and wind/solar/Hydro generator as rechargeable source. Before I can start looking at the actual rechargeable source I am focusing on the actual battery bank. The idea is to have a dedicated 'Lithium iron phosphate' bank for the motor, and a secondary '18650 3.6V, Lithium-Ion' bank for the boat itself. I would like to build the secondary bank to a spec where it also can be used as an emergency/backup energy source for the motor in case of ever needed. The battery choice for the secondary bank may not be the most suitable but as I have access to 18650's and enjoy the challenge/tinkering that is what I am set on doing. I have started with my secondary source (3.6V, Lithium-Ion - 18650's) and trying to work out what size BMS/s I would need, as well as how many 1865's per battery I would need.
This is what I know:
1. The motor will be something like this one or similar:
Rated Votage: 48V
Rated Power 10kW
RPP: 3888
Torque:28Nm
Rated Current: 250 Amp
Peak Current 400 Amp
2. I am thinking a 14S system (48V) where I potentially can connect multiple battery banks together to increase the Amperage.
Image for illustration purpouses only:
Questions:
- Is it the BMS that determine the load & charge max currents, in other word if I the motor has a peak current current of 400 Amp then I would also need a BMS that can handle 400 Amp (or do I maybe need an even larger BMS)?
- How would I calculate how many 18650 batteries I would need in each of the 14s packs to be able to handle the load?
- Can you have multiple individual batteries, each with their own BMS and connect them together?
Any thoughts, ideas or pointers of where I can start when calculating this highly appreciated:)
Thanks
Henrik
Let me know if you have any questions. :)
Hi DigiMer,
I hope all is well.
Only saw this message first now as not logged in since my first post. Boy do I have questions, not even sure where to start:)
1. Not sure if you have picked a motor yet, if you have then super interested in what motor you decided to get (voltage and kw?)
2. What max amp have you settled at in relation to BMS and cabling? This is where I get a bit confused as the motor I am looking at says 'PEAK CURRENT 400 Amp' but most people I have seen doing conversions have wiring for either 100 or 200 Amps.
Let's start there:)
Thanks DigMer!
Henrik
Hi DigiMer,
I hope all is well.
Let's start there:)
Thanks DigMer!
Henrik
1. I've not picked a motor yet... I had been really hoping to get a pod, but it seems like nothing out there suits me yet, so I may go with an inboard 12~15kw motor for a year or two, give the market time too mature. The voltage will be "48v" (<60vDC).
2. The current setup can handle 900A continuous, but I won't ever come close to that in practice. The quattro peaks at a sustained ~4200w, and the biggest motor I am looking at would peak at 15000w, so lets round up to 20kw, to be generous. That's <400A at 51.2v. Realistically, the galley (using the quattro) won't be going flat out if the conditions are bad enough that I'm also running the motor at 100% throttle. I think in practice, even half that would be rare.
Cheers!
Hi Digimer,
Thank you for your response as all really helpful information.
Apologies for me thinking out loud below, as most of this most likely hold very little value to yourself:)
I guess a pod would make sense as less risk of issues & water coming in via the traditional prop-shaft. Saying that, the pod has its own prod shaft so maybe just swapping one issue for another?
Looking at 'The Neds' videos I do not think he has ever exceeded 100amps as he is operating his vessel. If I understand it correctly his wiring etc. is maxed at 200 amps just in case. He is running a 10 kwh (water-cold) Golden Motor.
I was first set on a 'Lynch' brushed pancake (air/fan cooled) 10kwh motor but after watching the Ned I am now split as heat generated by both motor and motor controller shows a real need for proper cooling. My hope is to use the motor as little as possible (in and out of docking BUT know that in reality it would be used in many different situations so guess needs a safety margin in relation to size of power-bank and length of safe continuous use).
Interested in your choice of output power - 12-15 kwh. I guess that is based on your boats displacement? The boat I am building will end as an aluminum ( LOA 11m (36') and a displacement of 8000Kg. mono-hull so not 100% sure if 10kwh Brush-less (as in Neds case) would be sufficent. According to Lynch their motor would replace something up to combustion engine 50hp (which in my case would replace a Yanmar 39hp engine).
Anyways, wont bore you with more of my thinking out loud - One step at a time.
Thanks
Modular Hippo
The main two benefits of a pod are lack of through hulls (cooling or prop shaft), and lack of gearing (prop directly on the pod motor's rotor).
I should watch that, but I haven't yet, so I can't speak to it. I've been looking at the torque curve of my diesel and comparing it to what I needed when I brought my boat home. I saw around 2100~2200 rpm with occasional peaks around 2500rpm. This puts me into the ~8.3kg/m torque range. For that, and I might be over-specing I admit, I am aiming for about 15kw to get around there. I'm designing from the battery bank to peak at ~600A, though I highly doubt I'd sit there long.
This was my thought originally, too, but I've now changed my mind. The trip home had me motoring for days on end through the rivers and canals. I fully expect to do similar trips in the future, so I am designing for continuous operation now, and assuming head currents in these plans (hence my upgrade to a 15kw or better motor). I can imagine similar needs in the duldrums on a crossing, also.
I'm starting to look at inboards, as I just can not find a good pod option. Given this, and the comment above, I am planning to keep water cooling, reusing the seacock / sea strainer I've already got. Liquid cool the controller and the motor. I've spoken to others who've converted and getting their power derated from overheating is a real concern.
I'm at a handicap as I'm still working on paper, and I'm focusing on torque ratings at this stage. That said, I have NOT chosen a prop yet, and that will effect things. Also on that topic, I am putting a heavy priority on regen under sail, so my pushing efficiency won't be the greatest as a trade-off.
I've got currently a Yanmar 3GM30 diesel, and I used my ~760 nautical mile trip home (~875 statutory miles / 1400km) as a base for the torque I needed. Given then, and given I'm going to have additional losses if I stay inboard, 15kw is my current minimum size. Fighting currents on the Hudson / Niagara rivers really drove home the need to have solid pushing power. If you plan to be anywhere tidal or potentially need to sail to wind, I think going larger is needed, even if you know that 90% of the time you'll be fine with 5~8kw.
My LOA is 11.5m, LWL is 9.2m with a dry weight of 7,575kg, though my trip home was closer to 8 tonnes, I am sure. She's an efficient hull, double-ender with minimal wake. I was burning an average of 2.2~2.3 liters/hour.
Cheers, and sorry for the slow reply.
Madi
Do you have a harbor in mind?
In many parts of the states, nice marinas require liability insurance to be birthed there. In order to get insurance most reputable insurance companies require a marine survey. Non reputable insurers are not accepted by some marinas because of their pattern of insurance claim denial due to the boat not meeting Coast Guard regulations(they’re out). A marine survey will have a report of anything that does not meet US Coast Guard regulations or ABYC guidelines, having deficiencies (rot,corrosion, maintenance or safety) a general description of vessel and power type(s) and valuation. If the surveyor doesn’t see an agency approval on a system they’ll likely state it as so.
Insurance may not be an issue if you haul out on trailer(small boat). Also not an issue if you’re keeping the boat on a ball(anchorage) but that limits your ability for shore power to guest/visitors dock with limited means of electricity available and perhaps a premium if the harbor master realizes your energy needs.
Just something to consider beyond an electric boat build and limited solar area. During the time I had a boat in harbors, I knew of several boats that were asked to leave and had to go to a sketchy marina(your boat could get stripped). As a side note. Make friends with other people in harbor especially the “live aboards” they are your eyes and ears. Even so, in a nice marina with cameras, gates and live aboards, I got ripped off 3 separate times but only minor losses.
Not trying to be a buzzkill, but it needs to be known.
Madi
Hi DM,
Big thank you for your thoughts and feedback on my points as much appreciated!! Our vessels sound very similar in characteristics (displacement etc.) which is handy for comparing notes in the future:) If you get to watch The Neds you will find a water cooling solution that s very basic but seems to work fine. A heat sink cooled by water that in turn is cooled by 3 small 12V industrial fans. He has a closed system for the controller and separate closed system for the motor. The concepts is used in gaming computers so seems to be robust enough if you find the correct components. Gearing is an interesting subject as well as found that some with inboards have decided not to gear, and others have started of with gearing and wish they did not and eventually removed gearing and swapped to direct drive. Onward and Upwards! Thanks again!
Hi SkyPower - All really valid points!! Not even thought that far as I am only 25 % through the actual build of the boat. I am in the UK but guess the regulations and culture to be very similar to US so taking all your points onboard:) I did a solo 360 around the world tour on an old motorcycle between 2014-2016 and the learning curve was steep as I set of with very little research done - trying to be more prepared this time:) Thanks again for your info!!
It’s amazing how rules and regulations vary across the US. I had visitors from the UK and they were in shock with our laws and regulations. A phrase that is rarely used here anymore is “Well, it’s a free country”.
My boat was 43 feet long with 640 worth of horsepower. Efficient it was NOT, but it was a heck of a lot of fun at speed as long as you could keep the gallons to the mile out of your mind.
View attachment 161806View attachment 161807View attachment 161808
Wow - best of both worlds, camper on the water!!!!:) Lovely boat, got some muscle as well!!:)
It was a wonderful boat and the cat and I had made thousands of memories. IMG_0201.jpegWhen he passed away it was the last reason to not have the boat, fuel was the other reason. I knew that as long as I owned it the boat would go out every weekend which means $$. It was fully functional unlike most other boats in the harbor. Everything worked because it was maintained which means more $$. Unfortunately the guy I sold it to didn’t maintain it and I was in shock how far it had gone bad in four years. He sold it and I have lost track of it. Hopefully the new owners will get her back to the way I had it but it’ll cost serious money.
If I had to do it again, I would have gone a different route but still a houseboat but much bigger and slower. It would also not have any wood as part of its structure. My boat was fiberglass but it used wood as structure within the glass of which most had to be replaced at great physical expense. Wood does what nature intends, it rots. All the steel boats I’ve seen were again too much work, but the aluminum boats that had proper galvanic protection were in excellent condition. Several times I got a call from a friends that had engine trouble (bad fuel) and wanted to know if I could come and bring them back to harbor. There’s no way I’d try to do this with my big boat because once in harbor there’s no room for both safely. So I used my little RIB with a 20hp Suzuki outboard. Right before I towed (side tied) I swapped to the spare prop that I found at a garage sale. The prop was totally wrong for normal use( big diameter and shallow pitch) but perfect for this. It was then I discovered how a small engined boat can move 40 foot cruiser at a pretty good clip even when off thrust line. Imagine a how fast it could move a displacement hull (double ender/canoe) instead of a planing hull. So this got me to thinking, aluminum hull(s) and houseboat and big. A 65’x14’ or 70’x16’ Fun Country houseboat. Like this: IMG_0887.jpeg
Some of these during a certain period had a mold issue from a manufacturing problem, if you know where to look to find it. Some had twin i/o drives and those are just easier to delete with outboards(or convert). One of these boats could be converted to electric and the entire upper deck could be shaded with welded aluminum structure holding panels for the entire length and width of the boat. Electric propulsion and thrusters could probably be good for 8 to 10 miles a day with good charge and little headwind while still maintaining amenities, If not wait till it is, no rush in retirement. HVAC could be provided with MarinAir water to air heat pumps. I had one in the boat I had and it was so quiet. Water temperature here is cooler than air in summer and warmer than air in winter so you’re already that much more efficient with that type of heat pump. Could also go mini splits but the outside unit would make noise. When you’re on the river, silence Paramont. Holding tanks could be done away with by using incinerator toilets and having plenty of solar power that wouldn’t be a problem. The boat could use the freshwater around it to make potable water with filtration and UV treatment. Pretty much all the conveniences at home. Fresh meat is as close as a hook over side. I’m done with California and I know they have these boats in the Tennessee area too. I’m not sure if I want land or water under my feet. What ever I do, I don’t want to be a slave to it.
I'm in St. Catherine's for the refit, and I have insurance with liability (twice what's needed, just to be safe). I'm already working with a broker to find post-conversion insurance, and I'm being very careful to follow and meet (or exceed) all ABYC standards, specifically to ensure my own safety, and the ability to get insurance.
This is a good question though, sailboat insurance is not a simple "call, pay, get" thing. It requires careful thought and consideration, annoyingly.
Hi DM,
I do watch the Neds, he's very close to me. I've been meaning to reach out to them and see if they'd like to meet up. Perhaps eventually. :)
I am leaning heavily towards keeping the old 3/4" engine cooling seacock and heat exchanger, and using that to actively cool my motor and controller. I was speaking the Allure Arctic and they also mentioned that cooling is their big issue, and they're running Ocean Volt kit. So as much as I like the appeal of air-cooled simplicity, it seems like active cooling is the way to go.
Neds uses a modified PC water cooling radiator, iirc, and that would rely on fresh air coming from somewhere. I can see that being a problem, hence leaning towards water cooling.
As for gearing; I'm really leaning to two parallel motors, and using belt drive to the prop shaft. That will let me use simple pulley sizes to set my gear ratio, and avoid metal teeth of teeth gearing.
You may want to stay away from the insurance company that sounds a lot like a soup company. Happy to offer coverage, happy to take your money and happy to deny your claim.
It was a wonderful boat and the cat and I had made thousands of memories. View attachment 161826When he passed away it was the last reason to not have the boat, fuel was the other reason. I knew that as long as I owned it the boat would go out every weekend which means $$. It was fully functional unlike most other boats in the harbor. Everything worked because it was maintained which means more $$. Unfortunately the guy I sold it to didn’t maintain it and I was in shock how far it had gone bad in four years. He sold it and I have lost track of it. Hopefully the new owners will get her back to the way I had it but it’ll cost serious money.
If I had to do it again, I would have gone a different route but still a houseboat but much bigger and slower. It would also not have any wood as part of its structure. My boat was fiberglass but it used wood as structure within the glass of which most had to be replaced at great physical expense. Wood does what nature intends, it rots. All the steel boats I’ve seen were again too much work, but the aluminum boats that had proper galvanic protection were in excellent condition. Several times I got a call from a friends that had engine trouble (bad fuel) and wanted to know if I could come and bring them back to harbor. There’s no way I’d try to do this with my big boat because once in harbor there’s no room for both safely. So I used my little RIB with a 20hp Suzuki outboard. Right before I towed (side tied) I swapped to the spare prop that I found at a garage sale. The prop was totally wrong for normal use( big diameter and shallow pitch) but perfect for this. It was then I discovered how a small engined boat can move 40 foot cruiser at a pretty good clip even when off thrust line. Imagine a how fast it could move a displacement hull (double ender/canoe) instead of a planing hull. So this got me to thinking, aluminum hull(s) and houseboat and big. A 65’x14’ or 70’x16’ Fun Country houseboat. Like this: View attachment 161829
Ha Ha - I see a clear link between Cats and crazy boat projects..... I have two cats myself and convinced that I 'speak' cat (from the outside I probably just look a crazy cat-man):) If I understand it correctly the Digital Mermaid also gets allot of help in her build by her cat/s. Before I decided on building in Aluminum I did allot of research and all other materials scared me in one way or another (either from a maintenance effort point of view, or just unknowns I could not 100% control such as osmosis etc.). The curves and soft lines you can achieve with wood/glass is obviously a huge advantage but luckily I have personally always favored practicality over aesthetics so no loss on my side in that area:) Wow - A 65’x14’ or 70’x16’ house boat of that style, that is what I call a house boat!! And as you say, no lack of space to put your solar panels!! Go for it!!:)
I wish I was a diligent as you guys - Always passed on insurance whenever legally not required to have one and up to date never needed one. Saying that, one of these days will be the first and it will be a costly one for sure:/ Thin positive, ha ha:)
So cool that you are living close, you have to meet up for sure!! I believe The Neds started out with gear ratio and ended up with direct drive and seems like he is happier with that configuration. I guess all down to the motor/torque/prop etc. (that is what kills me the large volumes of parameters and no direct science from which end to start in your calculations). I have watched some parallel motor setups (mainly lynch pancake motors) and look like a good way to double the output. Looking at the traditional brush-less motors they tent to come in a 5,10,20 KWh configuration, you mentioned aiming for 12-15 so what is your thoughts about that? In relation to PC water cooling radiator, is it not just enough to make sure that you have enough movement of the air to make it cool the heat sink? Or are you worried that the heat in the motor/controller area will be so hot that it will only push hot air around hence not being efficient enough? Did not think about that side of thinks so a good point.
At one point I had 3 cats(in the boat) and one harbor cat. The harbor cat was my guard cat and kept the males away from marking my boat when I was gone. She was well rewarded. She didn’t keep one female from having kittens in my flybridge! One of my 3 convinced me that she’d rather stay home and not go boating. That left Alex(orange) and Bob. Bob made it to 24 and Alex 13. Bob was super chill with anything and Alex was more like my shadow, very much with a personality of a smart dog. When we got to the islands he had free rein as long as no one had dogs.
Fantastic!! Cat's are such good company, we are of course only there humble servants (we all know that) but still the best!! Alex looks well cool, amazing how they always manage to jump up on the stool you are about to sit down on only seconds before you intend to use it (as if they know in advance, ha ha). Had cat's since I was born and the last two are called 'Black' and 'Brown'. Live in the country side and they were accidentally born in our attic without us knowing. Two weeks later the neighbor moved and took the mother cat with her (also not knowing about the litter). Watched TV one night and heard some strange noises, found the two hidden in the rafters and after 2 days of offering them water and some food I managed to get them down. The basic names of 'Brown' and 'Black' temporary as the first intention was to find a good home for them. We are now 5 years down the line and they have kept their names and rule the house:) They are both out and about at the moment or I would send a photo (one is a male black & white 'tuxedo' cat, very James bond!!) the other brown with a beautiful pattern and longer hair (female). Who knows, maybe they will travel the seas with me one day if all goes to plan:)
Fantastic!! Cat's are such good company, we are of course only their humble servants (we all know that) but still the best!! Alex looks well cool, amazing how they always manage to jump up on the stool you are about to sit down on only seconds before you intend to use it (as if they know in advance, ha ha).
Exactly lol! He’d jump in the chair and look so satisfied with his eyes saying “Nice chair, where are you gonna sit?” So the next day I went to COSTCO and bought a second one (because they never carry anything you like very long). Next weekend I put both chairs down. He hopped in one and then the other. Funny to see the look of confusion and frustration as I wrecked his game.
Cooling the speed controller with a raw water cooled heat sink may be a good idea but materials with copper or brass(zinc alloy) involved could be bad. You could make one from 6061-T6 aluminum with your own dimensions. The hose fittings should be Marelon fittings and the cross hole plugs should also be plastic to avoid galvanic corrosion. A “plastic safe” pipe sealant should be used, many are not. I would stay away from Teflon tape because of the extreme pressure it can exert on the plastic before it gets tight and it can loosen. I wouldn’t use anything permanent like 3M 5200 or Stikaflex. The idea is that there are two plenums that connect the cross holes and if the entrance and exit are on opposite corners that no path is different in length. For this to work the water must fill from the lowest and exit from the highest. It can be inclined to still work. If the flow was reversed the water could simply take the first cross hole and not reach the others. This could be made in a machine shop or “gun drilled” a competent person in a home shop could do it as long as they get the holes started straight.
The sketch is purely an example and probably not the size you need. IMG_0903.jpeg
Ha Ha Ha :ROFLMAO:
