timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 19,911
I believe so.Is it best to order directly from SA?
Mine works perfectly.
I tried a 60v amazojunk one. It won't let the pi boot but it charges a phone, tablet and power bank no problem...
Thanks for the reminder I have some 12v 20ah lifepo4s laying around...
I haven't seen anyone mention these devices, I currently have one at a few properties. You can run 2 IP cameras with it, it does cloud backups, DNS, VPN, NAS features and a whole lot more, best of all it runs a VM's which is where I have HA running.
They're as little as $300 without drives, but there is a smaller model if desired, if I could only get SA to run as a VM I would be set with this single device running all my solar and home automation services, cameras, VPN, and network/cloud backups. Pretty amazing device for the price and it's not all dangled together with USB accessories.
Should be able to run in a linux container under proxmox very easily since it's native.For home assistant on a pi you want the orange pi 5.
8 core powerhouse in a micro form.
I plan on putting HA on one of these eventually. I run HA under proxmox on this for now.
HP ProLiant DL360p Gen8 1U RackMount 64-bit Server with 2×6-Core E5-2640 Xeon 2.5GHz CPUs + 64GB PC3-10600R RAM + 8×300GB 10K SAS SFF HDD, P420i RAID, 4×GigaBit NIC, 2×Power Supplies
Needless to say its not bothered by home assistant but when I played with it on other machines you know its there.
Thanks. I have that one in my cart and was going to order until I saw a review saying it lasted 3 months with a 48v setup.I've been using this one for two months, if you want USB C, just use a USB A to USB C cable, however you'll only get about 5v, (standard USB voltage).
Thank you.I believe so.
Thank you for the education. That likely explains why the usb power bank wouldn't boot it either.As I said previously. Raspberry Pi's (other than the Zero and Zero W / W2) do not use USB power supplies. They have a USB connector for power, and they use a similar voltage, but it needs to be over 5V. Sometimes you get lucky and get something that outputs a high enough voltage to make them happy, but most of the time that's not the case.
This provides a good explanation of the problem:
Raspberry PI 3 "Under Voltage" - Raspberry Pi Forums
forums.raspberrypi.com
Umm that's what that post is showing. Its the status screen from my proxmox server running a linux container with home assistant in it. Well that and about another 5 or so servers that run under proxmox on that machine.Should be able to run in a linux container under proxmox very easily since it's native.
Ok, I didn't see where you said container and the status screen is for the host so I thought I'd point out containers. I prefer to run Linux containers if possible, in fact I prefer them over docker at this point if docker isn't a requirement. Nice to see another proxmox user.Umm that's what that post is showing. Its the status screen from my proxmox server running a linux container with home assistant in it. Well that and about another 5 or so servers that run under proxmox on that machine.
Its handy. I use that proxmox server to run mirror images of the hosting machines. This way I can test stuff "live" without messing with the real production servers.Ok, I didn't see where you said container and the status screen is for the host so I thought I'd point out containers. I prefer to run Linux containers if possible, in fact I prefer them over docker at this point if docker isn't a requirement. Nice to see another proxmox user.
Cool, what are you using for the android container software wise..something in github?Its handy. I use that proxmox server to run mirror images of the hosting machines. This way I can test stuff "live" without messing with the real production servers.
I also have an android container that I use to run all of the android stuff from my phone so I can check car battery info and other android only apps.
It runs a minimum of 5 virtual machines 24/7 but I have run over 30 on it at times. Fans are noisy under any real load but its a powerhouse when it comes to running stuff. It has 8 front eject-able drives with 6 15k drives in raid 6 and 2 normal drives for backups and temp stuff in a nice 1u form factor.
I'm running this one :Cool, what are you using for the android container software wise..something in github?
Solar Assistant is a solar system monitoring and remote control app. It can also be used for home automation and load control.
I am using this poll to measure it's popularity on the forum. I have never used it before, but am curious how many people are using it.
It's the best, plus using home assistant as well.Solar Assistant is a solar system monitoring and remote control app. It can also be used for home automation and load control.
Count me in as well. I run about 10 VMs on a 2-Nuc cluster with an 8-bay Synology NAS for storage. Haven't really played with containers much, but as it is time to do some OS upgrades I get the value.Nice to see another proxmox user.
How do you view poll results?So with nearly 150 votes in, nearly 2/3 use or plan to use it.
If you have voted its at the top of the page.How do you view poll results?
We need to talk ?Solar Assistant is awesome and integrates well with HomeAssistant. Can not only get battery and inverter metrics in Home Assistant but can build automation in HA to change inverter configuration through Solar Assistant. Example: have HA integrated with Open Weather, if there is a storm coming into my area and my battery is under 30% it will config inverter to charge from grid, then back to only solar after storm event.
I've been running it on a Zero 2W for the past year and a half with no problems. It really is a great piece of software but I do wish he'd take down the two "coming soon" attractions in the changelog. It's been over a year and neither one ever happens; they just get pushed back a month with every release.Has anyone used a
Raspberry Pi Zero 2W
Raspberry Pi Pico W
Orange Pi Zero 3
for SA ? These are the current cheapest on Amazon I can find.
I've used https://a.co/d/4El6FAB for a Pi3 before I switched to a miniPC. Input 8-60V, output 5V 3A, perhaps an inline fuse would be good too.I tried a 60v amazojunk one. It won't let the pi boot but it charges a phone, tablet and power bank no problem...
He may, who knows?If will does the video.
