Amazon returns go to landfill. Which drives up prices for all of us.Here is what I would do..
Just buy them on Amazon, whichever you don't like, send it back.
Upcoming Vue 3 (in beta testing now) should have AC battery monitoring. Vue 2 does not.So I would like to find something that will monitor energy used, solar, and the batteries.
Will Vue do this?
The CT clamps of the Emporia will only work on 120/240 volt AC legs, not DC battery voltage.So I would like to find something that will monitor energy used, solar, and the batteries.
Will Vue do this?
I presume there is some filtering by Amazon based on price? They must have figured out it is less expensive than processing some returns so I concluded returns per se drive up prices and sending some to landfills has less impact on Amazon's cost than processing small ticket items. As an Amazon user, the return policy definitely has value to me.Amazon returns go to landfill. Which drives up prices for all of us.
Really, then where do all the used Amazon warehouse deals come from? I'm perfectly happy to purchase something someone tried and didn't like/understand for less money.Amazon returns go to landfill. Which drives up prices for all of us.
I agree and earlier mentioned that there must be a filter of some sort on whether returns go to landfill or someone who buys them in bulk and has the labor to sort and list them for sale.Really, then where do all the used Amazon warehouse deals come from?
Instead of a Sense, it might be better to just use Eyedro. I've had one since 2020 and used it to determine exactly what our power usage was to size the solar system.I've had Sense solar since 2020. Essentially it's a box with CT clamps for L1, L2 and one circuit it treats as solar, and a wifi antenna. As for recognising devices, it eventually identified the main things in my home, but the learning isn't great. It will talk to Kasa (or Wemo) smart switches to help with identifying specifics. Their cloud service tends to hiccup every now and again during which time the data is inaccessible, though it has a local buffer which covers if the problem was connectivity. The UX is simple enough and the app and web based interface are pleasant to use. It would be nice if it weren't so expensive.
No branch CT's, just mains, which makes it easier to install. Its supposed to be able to identify each load via the mains due to their respective unique power consumption profile. As you can see from the posts above, Sense doesn't work as advertised.
Emporia is much better. The only complaint I have with the Vue system is that ONLY the 2 channels for the main CT's are capable of monitoring bi-directional (NET metering) energy flow. This is a problem because one of our grid-tie systems ties into a subpanel that is monitored by 2 of the branch CT's. I've called them a few times over 2 years and they keep promising the fix is coming soon.
Energy in from and out to grid The Emporia Vue is capable of monitoring your solar production. You will install your Vue differently depending on whether your solar is a breaker-fed or a line-side tap installation. These installations are covered in the subsequent pages. If you are interested in monitoring how much energy you are pulling and sending back to the grid, you’ll need to utilize 50A CTs as described below. The 200A CTs that connect to your mains will provide net metering out of the box — displaying electricity used minus electricity produced. To ensure the Vue can correctly measure net metering, the 200A CTs must be correctly oriented and be placed between the meter and the incoming solar. For the Vue to be able to calculate how much energy your system is getting from and sending out to the grid, you’ll need to employ two 50A CTs on the incoming leads from your inverter. Installation depends on where these leads enter your system, which is illustrated in detail on the next two pages.
We have 2 grid-tie systems, One feeding into a main panel and 1 feeding into a subpanel. The 200A main CT's are bi-directional but the 50A ct's monitoring the subpanel are not.Their solar supplement installation guide seems to imply they can be bi-directional, but maybe I'm missing something - the quote below is from the doc...
You mean this ?FWIW,
Sense is no longer a small startup. Both Schinder and Landis+Gyr invested big money into the company.
Sense does an excellent job with the visualizations and solid energy report for total used. It just flat SUCKS for individual load tracking, and the Sense leadership simply doesn't care.
At least we agree on that point!I can't recommend anyone buy a Sense device unless they want aggregated reporting.
I don't think that is completely true.Amazon returns go to landfill. Which drives up prices for all of us.
My Enphase batteries provide 240 AC with the IQ8 Inverters built in.The CT clamps of the Emporia will only work on 120/240 volt AC legs, not DC battery voltage.
It's going to get confused about the direction, based on the above discussion, right? Because battery discharges and charges via AC.My Enphase batteries provide 240 AC with the IQ8 Inverters built in.
My question with the Vue work with Grid, Solar, and battery AC in/out. Can you program it that way?
Anyone using it like that.
Edit. Just found out that I can do this with what I got already. Looks like vue is really too basic for my needs. I have the enphase app but don't really use it much.
Hi, when is Vue Gen3 coming out? There was an email sent out for beta testing 3 months ago. Will it have bidirectional AC battery monitoring? Will it also have backup battery option for the Vue itself in case of brief power interruption to prevent Vue from rebooting?Hi OP, thanks for considering the Emporia Gen 2 Vue Energy Monitor. We're here if you have any specific questions!
while I would like to be able to get to the data locally, I also like to be able to see it away from home thru the cloud. If you do the flash update then you lose the cloud. Cant have it both ways. That was the good thing about Iotawatt, which cost more and now disconitued I believeI saw that too today. Pretty rare.
My bail out plan is to put the open source firmware in it.
Are you going to end up with one of those open source monitoring things that ingest from the API of various stuff and then present it in a single graph? I'm pretty sure it will have Enphase integration.
You can also get a Vue to monitor loads and ingest it into the same system. Vue can also be flashed with OSS firmware; I don't know if that has bidirectional capability on all channels. It probably has lower latency reporting, and reporting of stuff that is internal-only within Emporia (it doesn't show you everything in the app that it has internal metrics for).
I lose my view of my Vues for two reasons:So I ended up getting 2 of the Emporia Vue Gen 2's - one for my main panel and one for my off-grid load center fed by the inverter. Both were working flawlessly for several hours and then all of a sudden all the values for both total usage as well as the individual circuits went to zero and stayed there for about the last 16 hours or so. Then they suddenly started reading correct values again just a few minutes ago. It seems apparent they were having an issue on the cloud side that finally just got fixed.
My question is if this is a rare occurrence or not. Is the system generally reliable or does this happen periodically? Since these give you no access to the data locally, the system is entirely dependent on the reliability of their cloud services, so hopefully this was a one-off situation...
Amazon returns go to woot.comAmazon returns go to landfill. Which drives up prices for all of us.
