Hi all,
Im new to the DIY battery side of things and have built a 320ah battery using 16x3.2v grade A cells. I have added a JK-B2A24S20P BMS with RS485 converter which after some research seemed to be the best option as it has a 2a active balancer and has both CAN and RS485 inputs.
I already have a 4.74kw PV going to a X1 Solax 7.5kw G4 inverter.
From what I can tell the inverter uses Modbus RTU and the JK BMS CAN2.0A
I was naive and didn't check this first. is it as simple as buying a converter and plugging it in to allow the battery to speak to the inverter and vice versa?
Thanks In advance!
Communication documents attached
Thanks In advance!
