?Wood is a very poor choice for racking ( especially PT ), it will twist and bend over time causing likely failure of the panel frames, then the glass of the solar panels will fail.
And even worse, in some of the links above, the back to front supports are not tied together and, so all ground movement will literally pull the solar panels apart.
DIY has different meanings to different people. Are you looking for lowest cost, or what specifically?
1. DIY, build it yourself from stuff not made specifically from solar
2. DIY, build it yourself but select, purchase, and assembly products that are made for solar
I recently helped my brother-in-law put together a system. We purchased a UL listed (for bonding) ground mount system, "Sinclair sky-rack 2.0". The contractor-electrician that we hired to inspect the system saw the array and said, "Nice, who did this?" To some people DIY and "homemade" are often considered less than normal quality. But it can be "custom crafted" if done correctly. When I build my system I used IronRidge and made my own post from salvaged gas well drilling stem. I have also mounted panels to 2x4s with RV roof mount Z brackets, for my deer camp setup. Just depends on what your end goal and any local building code requirements are.
Here's an idea for a ground mount. Will recently showed himself assembling the new EG4 Bright Mount ground mount kit, which is a good price for what it provides.
So what if we used 30 Gal Totes like these, filled them with concrete, and then attach these racks to them the same way Will attached them to his driveway?
I estimate at 30 Gal, the weight is over 550lbs each. Just cast them in place.
Could that work? I estimated the cost at under $140/solar panel, which is cheap for a ground mount.
View attachment 121542View attachment 121545
Interesting idea!Here's an idea for a ground mount. Will recently showed himself assembling the new EG4 Bright Mount ground mount kit, which is a good price for what it provides.
I don't see the advantage of this versus something like the PowerField buckets, other than if you are using the adjustable angle Bright Mounts that gives you the flexibility to adjust the panel angles that you can't do with the PowerField buckets. Any other advantages, because the PowerField buckets would come in somewhat cheaper per panel.Here's an idea for a ground mount. Will recently showed himself assembling the new EG4 Bright Mount ground mount kit, which is a good price for what it provides.
Yes that seems like a great and straight-forward idea. BUT - can this - or have any had that approved/permitted by AHJ? If the Brightmount drawings and calculations show something different than Sonotubes, wonder if that would be a "problem" ..... ?Mostly buried sonotubes filled with concrete, as opposed to the blocks in the Brightmount docs are what I used.
