rbertino
I am in need of correct setup / diagram to connect the following:
4 250 watt solar panels yielding approx 200watt / panel
2 100/30 Victron mppt charge controllers
up to 6 AGM 12V deep cell sealed batteries
1 Giandel pure sine wave 3000/6000 inverter
1 IOTA DLS 30 battery charger
1 50A controller automatic transfer switch that automatically transfers between battery and grid power based on high/low volt threshold settings.
How do I incorporate all this with one inverter?
Otherwise, must I set up two completely separate systems? want to avoid to minimize cost if poss.
I assume i need more components...what do you i need?
here's a link to the transfer switch on amazon: https://www.amazon.com/gp/product/B07F12RDZ2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
thank you all for you help here
Current setup in image below
