15s vs 16s 26650 Cells
Johnjayjrv
I harvested a bunch of 26650 cells. They were in a 5s7p configuration and I want to configure them for 48v to charge a bluetti or Delta unit I have. Should I do 15s or 16s? I'm not sure exactly what the difference is so if anyone can give me advice that'd be great.
Most use 16S to best match typical operating voltages of a 48V lead-acid battery as much of the 48V equipment is designed to operate around those limits. Some LFP manufacturers choose 15S as that's truly a 48V nominal voltage, but that results in ~6% higher current for the same power and ~6% reduced capacity.
I've seen 48v Lifepo4 chargers that say they are for 16s configurations. Can I use one of those for a 15s configuration? I know the voltage is different, 54.7 vs 58.4.
