boarder2k7
- May 29, 2022
- 59
I'm seeing two versions of the Victron SmartShunt on Amazon for the same price. I believe that the one with the connectors on the face is the newer one?
Thanks for the clarification and the link.
What would the benefit be of the relay? Just something when all else fails to protect the batteries? Trying to think when I'd use that rather than trusting the BMS or the inverter to shut off.
That makes sense.
I guess I'll spring for the 712 as a "buy once cry once" as I probably couldn't buy a 500 ADC relay for the price difference anyway.
Plus that way I can use it as a disconnect for my initial capacity test on these packs rather than tripping the BMS.
How low of a level could I expect for a single 100 Ah cell? Currently sitting on a power supply pulling 1.3 A at 3.5V on one cell. PSU is set to 3.5V3.45V is very very close to 100% when the current drops to a very low level.
Also I ordered the 100A JK BMSs last night, unfortunately looks like delivery isn't until March.
Also I goofed in ordering these cells, the EVE cell isn't the same shape at all as the ones in the rack currently. Whoops. Much taller and thinner.
Fortunately it should fit in the gap left next to the 15th cell that's currently full of foam, but it will have to be laying down instead of having the terminals up like the rest of the cells.
Live and learn
Good point to check, yes the cell is only at 3.3V measured right at the terminals at the moment. I am indeed using alligator clips. I'll switch in a piece of wire bolted down with the supplied hardware and see what changes.
Knowing that it is of course charging slower with the clips, but that eventually it will equilibrate to nominally 0 voltage drop as current approaches 0, what would be the expected "idle current" for a cell of this size? I was seeing some statements that 0.5% C was where current would stop? So here that would be as much as half an amp.
Cell orientation never occurred to me, I assumed that like a lithium ion or lithium polymer that they were orientation specific. I charged the one server rack battery standing on its back because it was convenient so those cells were sideways for one charge cycle. I'll look in to that. If they don't permit that orientation I guess I have to buy different cells.
Bumped the PSU up to 3.65V and now running at 2.5 A. Fluke on the battery posts shows 3.32V so I guess I have a ways to go.
Unfortunately my attempt to bolt on some wires was foiled by the bolts sent with the battery. They are a length appropriate for busbars but not a ring terminal so back to the alligator clips.
I'm not really sure who made the 15s packs so no idea who to even ask about orientation. Some limited searching on approved orientations turned up a couple threads where people said they even had trouble getting Eve to comment on orientation, so I probably have 0 chance of figuring this out for my nameless packs.
I'm going to hope that one low rate charge cycle in an unoptimal orientation won't have caused much damage.
This seems like a recipe to overcharge to me. Your cut off current is 5A at 3.65V, but you are only charging at 2.5A. Either get some real wire or don't charge above 3.4V or so. I found it easiest to use 12 gauge solid wire for top charging. It is cheap, easy to cut to length, and thick enough that you should be able to tighten the bolts on it.Bumped the PSU up to 3.65V and now running at 2.5 A. Fluke on the battery posts shows 3.32V so I guess I have a ways to go.
Whilst thicker wires are always better, I fail to see why you say "This seems like a recipe to overcharge to me". If I'm not having a blonde moment, then if the bench power supply is set to 3.65V, it is not possible to "overcharge" the cell beyond 3.65VThis seems like a recipe to overcharge to me. Your cut off current is 5A at 3.65V, but you are only charging at 2.5A. Either get some real wire or don't charge above 3.4V or so.Bumped the PSU up to 3.65V and now running at 2.5 A. Fluke on the battery posts shows 3.32V so I guess I have a ways to go.
3.65V *is* overcharged. Using 3.65V to charge LFP is a way to get the charge to complete faster. If you don't stop the charge at 0.05C you will overcharge the cells. If you are going to use little wires, drop the voltage to something safe and give it time. 3.375V is safe for indefinite charge, and anything above that will require monitoring.Whilst thicker wires are always better, I fail to see why you say "This seems like a recipe to overcharge to me". If I'm not having a blonde moment, then if the bench power supply is set to 3.65V, it is not possible to "overcharge" the cell beyond 3.65V
