The smaller ones (8S 100A, 4S 100/120A) have as in the picture above small holes with M3 thread.
If you add a small M3 bolt and a small spacer you can easily secure it.
The 200A BMS doesn't have any mounts. I won't mount it on the in- and output busbars. Especially in a vehicle that will eventually fail (you're putting all the vibrations and the weight on the PCB)
I prefer mounting them with 4 plastic mounts and screw them to a piece of board, or use a aluminium L profile and tap into the heatsink to secure the profile
