Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,905
What would you like to see? This thread will be seen by myself and a few other YouTubers, so let us know what you guys want
Source components and retrofit an old car to electric.
Check out the new Chiko Groundflex (https://signaturesolar.com/chiko-groundflex-u2v-solar-panel-ground-mount-kit-ground-screws/) or check out APA Solar Racking. APA will quote a system that meets all of your wind and snow loads per your building codes.
So many good ideas and this one has me pacing.Yes! Shoot at fully charged 280Ah cell. Checked youtube, has not been done yet.
I thought for sure, someone would have made this suggestion by now...
Screw YouTube! Go Onlyfans!!!
I have been wondering about a power output comparison between high wattage panels and low wattage panels. The conditions would be cloudy days only. Which would give more power?
In order to have the same wattage for 250 watt panels, (then say 450 watt panels) you have to have more panels which means more surface area .
We all know that in the sunlight the 450 watt panels make more power hence fewer panels.
Will that extra surface area of the 250 watt panels grab more power on a cloudy day?
Where I live, it isnt about power in the sun, its all about power with clouds.
Just curious.
Exclude bifacial.
Expand on this by showing bad crimps and show how hot the get and how to identify a poorly crimped connection.Perhaps for the DIY crowd a video reviewing the basic usage of a multimeter, crimper, resistance tester, etc and indications when each would be used.
