Houseboat100
Hi, newbie to this group so please be patient if this topic has been covered in other threads. As the title infers, I have a houseboat that is an off grid system. 1000W 24v solar, BlueSky 50A charger, Xantrex 3000W inverter/charger, 5x150Ahr LiFeP04 batteries, Honda EU3000is generator. Our friends and family are more sensitive to the 100+ degree days in central CA. That has started the design of a significantly expanded system to take on more refrigeration, ice maker, mini split AC (240VAC split phase) which complicates the system. What I am planning on is:
-double solar (2000W total) 24vdc
-100A solar charger
-double battery capacity and set up for 24vdc (24 to 12vdc converter for local 12vdc loads)
-after reading some threads, maybe get a second 3000W inverter instead of getting a single, larger one. Depends on the answer on 240vac split phase generator or Victron transformer decision
-So big decision is whether to bite the bullet for a 7kva 240vac split phase RV generator and a new power panel, (2) 3000w inverters, and split the 120vac loads, OR a 5500W 120vac RV generator and use a Victron split phase transformer for the mini split. I’d have to use 3 120vac mini splits to do the job, so one 240vac mini split is much preferred.
Questions and suggestions appreciated.
-100A solar charger
