Good evening!
I am following along with Will's 24V 2000W DIY build. I have the Giandell 2000W inverter, and I am unsure exactly which size fuse I will need. I followed his link to the site to find fuse size (https://www.altestore.com/howto/recommended-inverter-cables-sizing-and-breakers-or-fuses-a62/), however the Inverter sizes on the table jump from 1500W to 2400W, so I did not want to assume an fuse size in between there.
Additionally, for the grounding bus bar, is the 100A the proper size?
Lastly, what size wire will I need for the remaining component runs? I believe it's 4ga, but would like to confirm.
Thank you in advance, and apologies if this is all obvious info (I am learning)!
