Yes I was reading the victron units voltage. I put a voltmeter on it but it seemed to be putting out 14-16 volts but the voltmeter seemed off as the voltage would drop to 0 a moment after connecting. I could break contact like slow pwm and could read voltage. I will try again with better light.Are you reading battery voltage or PV voltage on the victron unit?
So you were reading the panel voltages with a meter while they were still connected to the Victron SCC?
So you weren’t measuring VOC, or did you turn off charging of the SCC while measuring the voltage?
Typically victron units keep the solar PV voltage 5v higher than the battery, for your case it might be pulling the PV voltage down even lower.
Also can you post a screen shot of the Pv voltage trends of say the past day or so?
It is still in test mode which means the bare wires are twisted together. I have them in series now, which gives same voltage as parallel.How are you making the connections between panels? Are you still using those SAE connectors?
Yes I can see the panels on Amazon. Since they have a Voc of 22.41 and a Vmp of 18vDC you should see around 42vDC on your DMM before connecting to SCC when in series. When connected it should still be in the 36-38vDC range if you have good sunlight.
Does this link work? It works on my end, but it doesn't look right to me.
They can make more than 13.6 but don't seem to once hooked to the scc.Can you share a picture of how you made the connections between the panels?
And to confirm you took just one panel, not connected to anything and under decent sun still only saw 13.xx volts?
Can you zoom out and show the entire day?Trends screen
So reading 19.97 is the VOC.They can make more than 13.6 but don't seem to once hooked to the scc.
They are reading 19.97v unhooked.
