Some good threads and just a few videos on this and I'm still unclear the ideal way to arrange my cells. Will have 8 272ah lifepo4 nominally tied to either an lv2424 or growatt (so 2.4kw or 3kw). A 250a 8s Daly bms gets me a solid 24v battery using less than half bms rated amps and room for inverter spike.
Alternatively I could use 2 120a 4s overkill units and then run two diy 12v batteries series. Overkill says 120a continuous is no problem, so that's a continuous 4.8kw available with 3kw intended thru inverter.
Daly is cheaper, simpler, and 250a gives me lots of margin. Overkill is highly recommended but requires 2, increasing the number and complexity of components. I suspect both bt apps are similar.
I could use some constructive recommendations on 24v cell/battery config. The system will have shore and/or 3kw generator power as well as ~1kw solar to the growatt/lv24.
