Nois it code?
without the strain reliefs, the 4/0 cables would be hanging by their bolts on their respective bussesNo
But it works.
Yeah I see why you did that. Hanging there seems wrongwithout the strain reliefs, the 4/0 cables would be hanging by their bolts on their respective busses
I got the idea from david poz at this point of his video
I've watched a number of his videos and they tend to make me shudder most of the time with things done that work but are not up to code and would fail any sort of inspection. Does it work? Yes, generally. Is some of it risky for heat/fire problems or other issues? YES.
In summary he scares me but then again a lot of the youtube guru types scare me with doing things wrong and presenting them as a good way to do something.
Is it the strain on the buses you’re worried about?
Any proper electrical crimped connector should be able to withstand way more force than gravity.
How do you think they crimp wire on the grid with 100’s of pounds of tension on them? Yes there is copper conductor on the system, not everything is aluminum or ASCR.
That plate seemed pretty sturdy when he torqued the connections to it.the NEG buss is okay, it is the POS plate that has a weak area
did you watch the video segment by David? it explains the possible issue - it is the BOLT of the hanging circuit breaker
He describes the 250 amp circuit breaker that has a bolt to which the POS plate is attached. To that plate the 2 4/0 cables are attached (hanging downward), which puts a straining load on that circuit breaker bolt.
Also attached to that plate are the 4 array POS input wires, though they don't have that much weight.
I used to watch his videos but eventually couldnt stand them. Nothing necessarily wrong just, something about them I could t stand.the NEG buss is okay, it is the POS plate that has a weak area
