D
Deleted member 3614
Guest
getting water into the tank is vey easy with this van, its water feet is 3 feet higher than the tank and its in the perfect place to have the pipe placed inside, its all gravity fed.
Whats prior art? not hard of that.When it comes to patenting, you will find too much prior art.
I have one patent, and have researched several ideas, you have to show that there is no prior art.
was looking at our uk laws, 1 in 10 will make a patent, i,ve not seen any multi tilt systems for sale. there maybe somewhere i guess.
registered is the best, in Canada Lawyers use double registerWay back when, you had to have at least a model of what you wanted to patent.
They quickly found out you can't store all those models.
Now you need drawings/diagrams known as 'Art' and have a search done for similar ideas.
The Art and search are at your cost.
Now you can patent a general idea, like teleportation with Art.
Half the patents are to keep a better idea from becoming products.
You patent the idea, and it's not profitable for a company actually doing the work to develope a product because a competitor has the patent and won't licence it to the people making it a reality.
They do this to hold market share, the have a lesser product, get a whiff of something better coming down the pipeline, and race to the patent office to stop that product.
See battery technology over the past 100 years...
Petroleum & auto companies owned the IDEA of batteries that would have made Renewable Energy & electric vehicles viable & competitive.
The ideas for 'X' type batteries, and ideas for manufacturing processes were patented and left to rot, ensuring the market share for big fossil fuels energy and big auto.
I keep EVERYTHING, from bar napkins to writing down how the idea first struck,
And though patent litigation I leaned to keep doodles & write insprations/ideas down, stick a stamp on them and have them time/date cancelled at the post office.
99.99% come to nothing, but it's a cheap way to document the 0.01% that might go somewhere...
And you can bet if it makes any money at all, someone is going to infringe your patent (knock-offs) or challenge your patent,
The post office stamp is accepted by the courts 100% of the time.
Copyrights are even worse, and the courts accept the postal stamp time/date code 100% of the time also.
It's 'Poor Mans' documentation insurance.
Nice work, yes solar this time of the year grr, might as well use aa batteries lol.@Cloudy-Day
Well done for providing this post, I am going to be doing almost exactly the same as you using these.
Smith & Locke Spring-Loaded Animal Bolt Zinc-Plated 230mm - Screwfix
Order online at Screwfix.com. Zinc-plated. Ideal for use on gates, farm doors and garage doors. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
I am also in the UK and you are right Solar is not very effective at this time of year.
I have two vans one where the single panel will be a four way tilt and the other where the four panels can only really be 2 way otherwise they will shade each other plus I will only be able to access them from the side of the van
My panels are all mounted on Unistrut and it is very easy to bolt extra things like the spring bolts to Unistrut.
Unistrut is very strong!
I will be using rubber strips as a bump stop under the panels otherwise they will almost certainly rattle when closed because the hole for the spring bolt will obviously have to be slightly larger than the bolt itself.
The panels will need to be well support at the hinge point and prop when raised especially in very strong winds
Note also in strong winds with multiple panels there will be a noticeable sail effect which will easily rock the van.
This is my current panel setup
Crafter
Sprinter
And yes sitting on the van roof is a very nice place to be!
B and Q £2.67 i think.Cloudy-Day where did you get the black L brackets from?
I did a very temp install just to get my panel up in the air
I am going to buy a more efficient i.e. smaller panel and then will either use 8 latches to get a for way tilt or experiment with and old seat swivel base
That will give a finer degree of rotation until something gets in the way but it will require a support frame that can be safely locked down on the move.
yes but there's weight issues.look at how Unimog and other truck as well as Agriculture trailers do their 3 way tilt beds. Many ideas for panel tilting can be gleaned from their methods.
