Bigblockcutlass123
12k DMV Growatt inverter
Need a power supply that will run my raspberry pi off 48 volt. I bought one off amazon the will not run it. I need a good one.
How many Amp do you need?Need a power supply that will run my raspberry pi off 48 volt. I bought one off amazon the will not run it. I need a good one.
This would ultimately be the best solutionI am going to run my pi with a PoE hat (power over Ethernet) and connected to a PoE Network switch that runs off of 48V.
Thus, in my barn, my pi will be powered by the network switch, which is powered by my 48V battery (charged by solar). The switch will also run and power a camera and a point to point wifi radio that gives network connectivity back to the house, and thus VRM capabilities for my victron stuff.
Here is what I have. The hat model may vary based on your pi.
Power Over Ethernet HAT (Type C) For Raspberry Pi 3B+/4B, 802.3af/at Power-Sourcing Equipment Required | PoE HAT (C)
Power Over Ethernet HAT (Type C) For Raspberry Pi 3B+/4B, 802.3af/at Power-Sourcing Equipment Required | PoE HAT (C)www.waveshare.com
(POE-Switch0504GD) 5 Ports DC12-48V Input Full Gigabit POE Switch with Voltage Booster
DC12V-48V POE SWITCH - Support DC12V-48V input and standard IEEE802.3af/at POE output with built-in voltage booster. 5-PORT FULL GIGABIT POE SWITCH - Provide 4 IEEE802.3af/at 30W POE ports and 1 Gigabit uplink; All ports 10/100/1000Mbps self-adaptive full duplex; Total POE budget 120W...linovision.com
I got tired of searching through products with questionable reviews. I ended up with a Victron Orion-Tr 48/12-9 that I found used on ebay for $35 delivered. With a solid 12v, it is easy to find quality power adapters.Hi @Duckcm18 are you still using that successfully? A review on Amazon says it died after two months.
The camera in the barn is to watch my sheep and goats without having to leave the house.This would ultimately be the best solution
This one is working great for me:I got tired of searching through products with questionable reviews. I ended up with a Victron Orion-Tr 48/12-9 that I found used on ebay for $35 delivered. With a solid 12v, it is easy to find quality power adapters.
I can second that, as I have the same one powering my Pi 4.I know this isn’t 24 V, but I wanted to share with the community that this device is working perfectly for powering my pi 4
DC 7-60V to 5V Voltage Step Down... https://www.amazon.com/dp/B076ZLHLD3?ref=ppx_pop_mob_ap_share
