thebeavesknees
First things first:
Hi. I'm The Beave. I am an odd duck, which is especially strange since my nickname is an entirely different creature, but, here we are. This will be along post, since I have quite a lot of explaining to do about my situation, requirements, possible solutions, and some dry, self-deprecating humor.
Foundations:
1. I live in a 2022 Forest River Wildwood 22RBS, and I love it, but, it is not finished well at all. I am currently replacing all the really terrible outlets in this thing after a suggestion from my BIL (brother in law), who is more familiar with RV wiring, mentioned that most RV fires are caused by faulty wiring, and I can certainly say that is the case here. The main 30A inlet had a loose screw on the hot lead, and that could very well have led to a fire. I replaced the inlet socket, and checked the OEM outlets and found too many loose wires and generally detest "vampire" wiring systems.
2. My home is powered by a new run of wire to a pedestal that I plug in a typical RV power cable to. My BIL dug the trench and pulled the wires through conduit, all to spec, as far as I am aware. This being a 30A RV will play into some of my decisions later, so please bear that in mind.
3. I lucked into picking up 4 REC Alpha (not the extra fancy once, just the penultimate Alphas) 405W panels, which will cover most of the roof of my RV, aside from the center section around the (current) AC unit mounted as typical on the roof. I have already decided on how to physically mount these panels, and will start doing so withing the next week or three, pending some cooler weather, as I am NOT going to be up on a hot roof after working 10+ hours a day as welder. I get enough free sauna time at work.
4. I have decided on a 48V system as my home does not have the space that longer trailers do for separated utility bays. I have a single pass through storage, and possibly one other place to install a system. More on this later, as location has some fairly pertinent decisions on component selection.
5. I know enough about wiring and electricity to be dangerous. I know how to make proper connections. I have proper crimping tools. However, I do not know the NEC much all, and, in some cases where the NEC is inconvenient, I WILL ignore it. That is my choice, and if you want to rant at me about that, fine, but, I suggest that you don't as I do not care about nitpicky stuff so long as it is not a direct threat to my person or my home. (An example would be requirements for conductors to be in conduit from the inverter. I am not inclined to follow this as it would make routing exceptionally more difficult, and NOTHING else in this trailer is wired that way.) I WILL listen to advice that is meant to keep me safe and not roasted from a fire or electrocuted, though, I haven't died from electricity yet, and by all accounts I likely should have.
Needs:
1. I need to have a system that is robust enough to survive less than ideal utility power, for when I do eventually move from my current location. RV parks have notoriously terrible voltage issues. I do have s surge protector at the pedestal, and would upgrade to a smarter EMS when I do move, but I would like to not worry about killing an inverter with a brownout from 100 campers running all their ACs at once.
2. The system must be quiet enough to not be annoying. Right now, the overhead AC is doing its job, but my goodness is it loud doing it. Eventually, I will be installing a minisplit, but that is going to be discussed further later.
3. Intelligent bypass ability. I would very much like to prioritize the 1620W capacity (If I get 1kW input due to the angle/direction my trailer faces, I will be more than happy, so I don't think I am being unrealistic with that expectation) to charge batteries and run stuff during the day. Since I am the only occupant of the RV, the biggest loads are AC and heating. I use propane for cooking, heating, and hot water (for now), but would like to transition those loads to more efficient means, or by using any excess power from the panels during the day to minimize usage after dark. Some AIOs seem to have issues with this, but I do not know if this is just a settings issue or something that is a design/software issue.
4. The VOC of the panels I have is near 50V. Max current is 10.3A. If I want to run my panels in series, I will need at least 200V (so most likely a 250V) MPPT input. I can run the panels in a 2S2P configuration, and there may actually be some advantages to that since I will have to deal with some shading as the sun gets lower in the winter, but that is something I wish to discuss with people who know more than I do. If I did decide to run a 2S2P config, this would put the working voltage between 80-100V, and that is too low for many of the newer inverters on the market. This is something I expect to have a large effect on my choice of AIO.
5. I WILL be leaving the current 12V system intact. This will be with the knowledge that there will be some silly conversion losses in the system, but I have decided that is a perfectly acceptable compromise.
Dealbreakers:
1. I am NOT willing to convert my RV to 50A input. It was hard enough pulling 3 8g conductors through the conduit, and I am NOT digging that trench again to go larger. Also, 30A is perfectly adequate for nearly everything I expect to do in my home. If anything, I am willing to expand the system, space allowing, to 240V split phase with another AIO added to the system, IF I need more power. IF.
2. A very noisy system, especially if the system is installed under my bed (which flips up, sort of like a Murphy bed to access the storage, a feature I rather like), would likely drive me batty and that is a complete no-go.
3. My RV is not large, so all the possible places to install everything are small. If I can't fit a unit in either of the two spaces that I am considering, then I can't fit them in the RV. That being said, I have seen quite a few RV installs online that completely ignore the manufacturers spacing requirements. How small is too small? How much air is needed to cool these units adequately? I have briefly toyed with the idea of getting one of the water-proof, outdoor rated units and slapping that on the rear of the RV, but, I think that is probably a poor solution long term and I also detest the capacitive buttons that those units seem to be plagued with.
4. 120V input in mandatory. It is annoying that there are no (to my knowledge) units that can take 120V input, then invert it via the DC bus into 240V split phase. (Yes, I know the output would be completely limited by the input current, but you know what? It would run a mini-split just fine, as there are millions of cheap Chinesium VFDs that convert 120V single phase into 3ph to drive motors on things like mills, lathes, drill presses, etc.) That seems to knock out many of the bigger inverters like the LV6048.
Preferences:
1. Not needing a battery. I do not want to have to buy a $1500 battery just to turn the darn thing on and start using the MPPT to generate 120V. That's such an obvious design flaw when you have utility power available to provide a base. (Even if you didn't have utility or a generator, it would still be useful.)
2. Not requiring a very large inverter generator to charge batteries or support useful loads (let's say up to 1500W). I am aware that an inverter generator is pretty much required, but would also be willing to add in a separate battery charger to charge the batteries and get clean power through the inverter.
3. Not Victron price points. Victron doesn't have an AIO that I can see (for the US market), and I would rather not spend that kind of money and then have to wire a bunch of stuff together. I prefer the simplicity of AIOs, even at the risk of inferior quality/longevity.
4. Being able to flip a switch and bypassing the inverter in case it dies (and one of the reasons why I will not me messing with the intact power system of the trailer).
5. If I decide to get a 240V minisplit next year, being able to power that with minimal cost/hassle. I have been reading about people's experiences with 120V minisplits, and I am fairly happy with what I have read, but . . . My neighbor is an HVAC guy and he can get me silly good prices on Mitsubishis. (I know there are 120V Mitsus, but, they don't seem to have as efficient/good heating performance, and if that is the case, I think it might be worth it to set up a 240V system for that purpose.)
6. I dislike being a beta tester. Something more tried and true is usually my preference.
Splitting this post in half since I went over 10k characters . . . (Yes, I talk this much in person, too!)
Foundations:
Needs:
Dealbreakers:
Preferences:
