90 kWh battery capacity.90 kw for 1 space is an atrocious waste of power and money. How do you figure so much is necessary remember these are tiny homes probably 500 Sq feet
30 kWh per day, times 3 days. Seems pretty straightforward to me.
I ran a quote for someone with a similar business plan. He had 30 acres about 50 miles Las Vegas & wanted to run a 100% off-grid RV park. We came up with almost 30 kWh/day/spot. This did not include the energy needs of common facilities & infrastructure (office, restrooms, etc).
Just come I'm an engineer, doesn't mean I still don't slip the odd decimal point. Thanks for catching that.
Glad I went with the 30 kWh per day number. Hopefully, the rest of my numbers still end up at about $14K per cabin (assuming you allow for reserve battery capacity to cover cloudy days).
The 30 kWh/day/pad estimate I arrived at *did not* include summer months, since the RV park would mostly empty given that it is in the Nevada desert. Ideally it should be a lot lower. However, most RV'ers who pay for a full service site expect unlimited electricity service and will not attempt to conserve. We even considered 3 tiers of metered service.Just come I'm an engineer, doesn't mean I still don't slip the odd decimal point. Thanks for catching that. I live in Phoenix AZ, so those power numbers seemed legit. I have paid $500 a month for power here in the summer.
Tightwad rule #1: Spend other people's money. A development will always have ongoing utilities expenses (water, sewer/septic, garbage collection, road/facilities,etc.) so I see no reason power shouldn't be treated the same way, especially when you cannot control/dictate its consumption by the consumer. Presently, new Lennar/KB/et al. market homes grid-tied with great success, but solar is a selling point, and the proposition of them selling these homes as 'off-grid', but solar, changes that selling point drastically.
Hawaii has only a 7Kwh average per day probably because they have expensive power and mild climate.Glad I went with the 30 kWh per day number. Hopefully, the rest of my numbers still end up at about $14K per cabin (assuming you allow for reserve battery capacity to cover cloudy days).
Yup, one space is the break even point. More than one space, just get grid power, you will never break even (the batteries will die before you recoup your investment).Hawaii has only a 7Kwh average per day probably because they have expensive power and mild climate.
If he cooks and heats water with propane and the RVs are under tree shading then I don't see why
it couldn't use way less than 30Kwh a day.
Also 300 watt panels can be a lot cheaper than $200 each. More like $80 or less.
So $1600 instead of $4000 saving $2400
Over panel to run AC on solar power during the day.
For one household $14,000 is a winner even at 30Kwh a day over $18,000 to bring in grid power.
I think you guys need to learn how to conserve energy. We only use 10kw per day in a 2000 sq ft house with 3 people living in it full time. The OP ststed an average of 500 watts / hour or 12kw per day.90 kWh battery capacity.
And you can't seem to understand this is for a rental property to be rented to people care nothing for our solar power sensibilities. They just want to leave the door open with the AC running and dry their laundry with a hair drier.I think you guys need to learn how to conserve energy. We only use 10kw per day in a 2000 sq ft house with 3 people living in it full time. The OP ststed an average of 500 watts / hour or 12kw per day.
Im not saying this is or isnt a good idea you guys just cant think outside the box or just dont want anybody to succede it seems like.
How do you know that?And you can't seem to understand this is for a rental property to be rented to people care nothing for our solar power sensibilities. They just want to leave the door open with the AC running and dry their laundry with a hair drier.
The OP has enough info now to run the numbers with 12Kw per day and cheaper solar panels. Racking, wires, fuses etc can add up too.I think you guys need to learn how to conserve energy. We only use 10kw per day in a 2000 sq ft house with 3 people living in it full time. The OP ststed an average of 500 watts / hour or 12kw per day.
Yes for sure I agree 100% and just hope they are not discouraged from the postings last night. We need way more information!The OP has enough info now to run the numbers with 12Kw per day and cheaper solar panels. Racking, wires, fuses etc can add up too.
He has not replied or given more info about who is living in the 6 RVs and if they will pay a monthly fee for power to help pay for the initial cost.
Lots of unknowns that would make a decision.
Yes Racking is important thing I forgot but he said he is hoping to use his roof. My ground mount racking cost more than my panels although I got panels for next to nothing.The OP has enough info now to run the numbers with 12Kw per day and cheaper solar panels. Racking, wires, fuses etc can add up too.
Not to mention a back up generator, likely auto start, so inverters that can communicate that.Racking, wires, fuses etc can add up too.
The guy for whom I ran the quote had managed RV parks and has a lot of 1st hand experience with the clientele. The typical RV'er who arrives in a 40 ft class A motorhome is simply not energy conscious; even more so when they are not *directly* paying for the energy. Encountered something similar in the motel business. Many solar (PV & thermal) retrofits we did for motels had a common theme - the guest is simply not energy conscious. For example, according to the motel owners, over 70% of the guests leave the hot water running while brushing their teeth. Many motels have installed door activated switches that shut off electric power to the rooms. Implementing hot water saving gadgets is not that easy.I think you guys need to learn how to conserve energy. We only use 10kw per day in a 2000 sq ft house with 3 people living in it full time. The OP ststed an average of 500 watts / hour or 12kw per day.
As forums grow they seem to attract more an more people who live to show how smart they are and how stupid other people are.
