What is the best way to add a active balancer to a battery pack? I already have a BMS installed with charge balancing but it doesn't seem to sufficient as the cells are aging. Can I just make a splitter for the BMS cell monitoring wires that I already have? Is there an active balancer that can act as a pass-through to the BMS? Or do I need to run entirely new cables for the active balancer? I'm trying to get an idea of what is usually done and what might be a simple solution without adding too many more connections to the pack.
The pack is 24S so its a few handfulls of wires to cut/strip/terminate if I need to add all new so before I start that process I figured I'd see what others have done before me.
Thanks!
Thanks!
