pretzelboy
Hi all,
I currently have a home with a functioning but inadequate roof mounted grid tied 4.2 kw system.
I have an outbuilding that is 200 ft from main house and is fed by a subpanel with underground wiring from a 60 amp breaker in the main.
The subpanel itself 100 amps (main breaker that it came with), its draw is limited by the 60 amp breaker in house/main panel
Feeder cable is 1-1-1
I would like to add a complete array/system to this barn roof (which has excellent unobstructed sunlight) that would feed into the subpanel.
no battery just grid tied but feeding (back) to the main house/panel.
Is this possible? practical? could someone give advice on methods for interconnect-I've read that AC powerline/trunk (after the inverter/microinverters) you would wire into a smaller breaker on the panel ( which sounds...weird) wouldnt you wire directly into the sub panel's main breaker sharing with the feeder cable from house?
Also if someone could explain any limitations so I can size the system correctly
Thx
G
Thx
G
