Boron
Hi Guys
Hope this is not a dumb question but AFAIK all the microinverters are of the grid-tie type and require connection to grid/main voltage so they can synchronize. Indeed if the mains trips then sync volts lost and the system shuts down (seems odd cant be right pls advise).
My planned system is to use panels with individual microinverters sending ac240V to my auxilliary Dis Board. I do not want to connect my system to the grid. Hence I believe its called an "Island " system.
I will have a manual (at the moment) c/o switch to power house base load eg my PC stuff (thru a UPS) and other non-surging loads. This can be configured base on operating experience eg Fridges, freezers etc.
My thoughts are that I need to provide a (alias 50hz mains volt reference to the microinverter grid but it wont ever allow export of power into in - blocking diodes - I thought a simple low power say 100VA UPS (sine wave) could do the job and this would be power from my main battery storage used to store excess power from panels.
Would this allow the microinverters to net together with their independant ac outputs?
OBTW I have realised that there is something called a "Smart Grid SG" system of microinverters which have wifi (up to 99units) back to a hub up to 5m distance line of sight and then to a PC App? These are ca £120 ea/panel + £50 for the hub unit? vs basic microinverter £50 ea
Anyone experience this stuff? is it OTT? or only for the Big Boys
My objective is to be able to monitor the performance and SOH of individual panels. It seems to me that the simple set of dc strings just hangs together and you hope for the best. Controlling individual panels with MPPT on board can give extra power efficiency AFAIK. Also one bad panel brings down a whole string without warning?
Your comments will be much appreciated as I am trying to understand this "Smart" system.
