In your screen shots, all I ever see is 60 Hz. But some have "freq-watt under freq" highlighted in green.
In post #1,765 it dropped enough to show as 59.9 Hz.
I agree, it is going active very early. But I can see it happening. It is a very tiny amount of current. 86 watts at 240 volts is 0.358 amps. That is about my minimum static load back in my main panel. I just had a little fun since I wanted to heat up a Pretzel dog anyways.
Here is the screen, with my PLC monitor window. The PLC window is not very user friendly. In the simulated LCD window, you can see the Batt Volt at 57.670 and in the XW DC voltage readout, it rounds it to 57.7 volts. The Solar panels are nearly done making power, and I am starting to use some battery. This is my base load in my main panel, it is small. The XW window shows it as 88 Active Watts with a -0.9 power factor. My PLC asks just for Watts and it is showing 107. Battery watts is -670 in the XW window, and -664 in the PLC window. Again, the XW is rounding it off. I am not showing the lower section, Output of the XW. But the PLC is showing the output side running at 521 watts. That is my refrigerator, lights, this PC etc.
In the PLC green window on the left side, variable "U" is the current the PLC is telling the XW to send back to the main panel. In this snap shot it shows 391. That is milliamps of grid sell current.
And if you look in the XW window below th PLC screen, you see AC1 active current 0.4 amps, again, rounded from 0.391 to 0.4 amps.
Now I press start on the microwave oven, which is currently plugged into an outlet off of the main panel, not the backup loads. This places about a 1,700 watt load in the main panel.
Now we see the variable "U" in the PLC is now calling for 7,745 milliamps to the main panel. And if you look at the AC1 Active Current, there it is 7.7 amps. But that is at 240 volts. The microwave is only on L1. 10.5 amps are going out L1, and 5.4 amps are going out L2. Most of the L2 current is going to the utility transformer and coming back in to help power the oven at nearly 15 amps total on L1 in the main panel.
I am actually very surprised it works as well as it does like this. And the power meter totally ignores the phase imbalance. I have had it exporting over 15 amps on one leg, and importing over 14 amps on the other, and it shows just like 50 watts going out to the grid. I just hope they never change the meters to read the current of L1 and L2 independently.
