GXMnow
Solar Wizard
- Jul 17, 2020
- 2,715
Just got my Mar. to Apr. So Cal Edison bill. Last year, the same billing cycle, I exported 150 KWHs. This year, thanks to the DC panels and my son being away at college, I exported 326 KWHs. That is an increase of 5.87 KWHs every day. Most of that is from the extra production with the additional 2,000 watts of DC panels.
Production should still increase even more as the days get longer. Mid May was my highest production numbers on the Enphase panels. I am hopeful that the extra production and my stored up energy credits will now cover most of the energy needs to run the A/C this summer. This morning, watching the sun come up, the DC panels are covering the load from the inverter for over a half hour before the Enphase system starts making enough to start charging the batteries from "extra" power. At 8:30 am, the XW is still taking 60 watts from the batteries to cover the loads, but the DC system is already pushing 200 watts into the batteries.
I know it is not linear, but I did a bit of math to try and get a rough idea here. From midnight to 8 am the battery voltage dropped from 5.89 to 53.17. A drop of 2.72 volts. There was basically no solar power during that time, so the only current was from the XW drawing power to run the house. The XW drew 5.6 KWHs in that time. 5,600 / 2.72 = 2,058 watt hours per volt at this middle state of charge. If I allow the battery to run down to 51 volts, that is another 53.17 - 51 = 2.17 volts. Rounding down a bit... 2 x 2,000 = 4,000 more watt hours can be taken before the inverter hit's shut down. That is running the A/C for 75 minutes after the sun is down. But I am exporting over 15 KWHs a day. If the battery was fully run down, It would need 5 KWH's more to fully charge. That still leave another 10 KWHs to run the A/C while the sun is up, that is 2.5 hours (150 minutes) of run time. so in theory, I can get over 225 minutes of A/C run time and still have a zero electricity usage from So Cal Edison. Of course, the reality will happen in a couple months. Let's see how it compares to theory.
