ericfx1984
- Oct 10, 2021
- 742
For those of you that have do it yourself off grid systems... I was wondering what your experience has been
Does it make more sense to overpanel an existing solar charge controller? Obviously you're not going to get much more, if any, additional peak output... But it will definitely smooth out your overall output meaning that you will probably reach charge a little sooner and charge later into the day and be running at full charge for a longer period
Where does it make more sense to just add another controller?
One thing that I've noticed about running additional controllers is oftentimes the additional panels and solar charge controllers rarely see their full potential as far as output goes... In my case I had added a few 60 amp MPPT solar charge controllers, while my overall production certainly increased significantly... I found that by and large one of the controllers always seem to take the lead especially in the last 20% of battery charge... Not to say that we never saw higher outputs... Just that I never seem to get anywhere near full output that the controller should have produced
For instance a 750 watt array may only put out 600 Watts at most and might average somewhere in the 4 to 500 watt range
Best as I can tell what causes this is that the controller that's putting out the most power has its voltage red by the other controllers in the system... This causes the other controllers to stand down from a more aggressive charge to a float charge... Oftentimes resulting in anywhere from 25 to 50% reduction in energy production
Curious what everybody has seen, what their thoughts are...
Additionally I might ask if anybody has any familiarity with the EPever link kits? Not sure what they're actually called but basically it makes one controller a master and all the controllers after that slave... Which seems to help keep them in the correct mode
