tomsaffell
- Jan 10, 2022
- 3
I'm looking for an efficient 12V inverter in the 1200W to 2000W range, which will mostly be used at ~500W.
In the past I've bought Victron gear, and been very happy, but I noticed that Aims make an inverter that they rate at 95% efficient at 1/3 power.
Vs the Victron Phoenix which they at a max efficiency of 91% for the 12v/1200w
Is this a fair apples-to-apples comparison? Can I actually expect to get higher efficiency from the Aims around 500W than the Victron?
Any other differences worth considering (I know the warranty is 1yr vs 5 yr)
Or any other high efficiency inverters in that size range that I should consider?
Context: this is for a travel trailer, where most loads will be 12V, so the inverter will be off most of the time.
thanks
tom
thanks
tom
