Product description says:
"Waterproof 100Ah 200Ah 300Ah 400Ah 12v lifepo4 battery lifepo4 rechargeable battery Inverter battery for UPS electric car triciclo electrico
Remark: We offer lithium, lifepo4 and ni-mh battery, accept customized battery pack, we can't update all items here.
If any battery you want, please take it easy to contact with me tell me the capacity voltage and size you want, thanks.
Descriptions: Nominal voltage : 12V Nominal capacity : 100Ah 200Ah 300Ah 400Ah
The maximum charge current: Less than 50A( can customize)
Continuous discharge current: 100A(Adjustable on demand)
Service life: more than 2000 cycles
Charging temperature : 0~45 ℃
Discharge temperature : -20 ~ 60 ℃
Storage temperature : -20 ~ 45 ℃
Weight : 10KG 20KG 30KG 40KG
Operating voltage range: 10V-14.6V
Battery temperature protection: 60℃±5℃
Output and parameters: high current positive / negative connecting column (As picture shows)
Battery storage period: 98% power (6 months)
Battery warranty: 12 months (free warranty)
Product advantages: Easy to carry, high capacity, high release platform, long working hours, long life, safety and environmental protection
Application: electric machine, xenon lamp / searchlight, inverter, handheld devices, wireless communication equipment, monitoring equipment, power equipment, medical instruments, relief equipment, emergency lighting /LED lamps, traffic signs, portable small household appliances, electric tools, automotive and industrial equipment reserve power supply
Safety Precaution 1.
Do not throw battery into water or make it wet
2.Keep the battery away from heat source
3.Do not throw the battery into fire or heat the battery
4.Forbid to hammer to trample the battery
5.Forbid disassembling the battery in anyway
Package includes : 1pcs 12V 100Ah High capacity lifepo4 Battery pack, with BMS build-in. 1pcs 14.8V 10A
Charger(EU/AU/US/UK plug for you chose)"
Only two things I recognize that have me a but worried is just 1 year guarantee, and 2000 cycles. As well as it looking a bit funny.
Best, Shaggy
