Anderson Power Products Powerpole and SB Series connectors are available at Powerwerx. Shop for different gauges today!
powerwerx.com
As @Will Prowse noted in a recent video, even the ones rated for 45 amps will get very warm when run at rated capacity. My first try was running 40 amps through the 45 amp rated connectors:
Recommended for use with 10 gauge wire. Unassembled sets can be assembled in any configuration. An included slotted roll pin prevents the housings from sliding apart.
powerwerx.com
The 50 amp rated connectors worked much better (didn't get nearly as warm):
Available in Blue, Gray, Red, Yellow, Orange, Green and Black. Recommended for use with 6, 8 and 10 gauge wire. Kit includes the housing and contacts needed for a single connector.
powerwerx.com
So, leave yourself a comfortable margin, even the silver-plated pure copper connectors will get warm.
Yes, I used the proper crimp tool for all of them, no I don't solder them.
How about the twist lock welding cable connectors ?
These are very rugged and the standard in the welding industry for up to 300 amps.
Much more solid than an Anderson connector, and fit the appropriate sized welding cable.
