There is good news and bad news:
The good:
There is now a firmware version 15.17 on the jkbms.net site:
Furthermore, there is now a new android app verison 4.19.6 on the same site.
www.jkbms.net
I found that if you update the new 15.17 firmware AND use the new android app, you can now select mode 11 (luxpower) for the CAN protocol.
This firmware seems to work with both mode 2 (pylontech) and mode 6 (luxpower) on my 6000xp inverter.
Sadly that is the end of the good news, because the new firmware still suffers from the same issue with luxpower (and many other) inverters which shut off the charge controller as soon as the battery hits 100% SOC. This behavior is unchanged, so I still need to the pb-acid setting on the inverter to get it to actually charge my battery above 3.4v.
Other than that it does seem to work fine, the pack SOC, voltage, capacity, charge/discharge limit etc are all are reported just as they were using the pylontech protocol.
2 other observations:
1. The charge/discharge current limits as reported by the EG4 app are divided by 10 (actual discharge limit = 200A, reported value in eg4 app is 20A, etc). The system does actually work correctly (charge current is correctly limited to actual charge limit setpoint in BMS), so I think this is a bug in the eg4 app (maybe related to the new generator boost firmware)
2. Curiously,
and perhaps worryingly, when I tried to go back to the pylontech protocol (mode 2 on both jkbms and inverter) the battery capacity reported by the inverter and the eg4 app was stuck at zero. This is worrysome, because I know that this was working in the past, so I suspect that there is some sort of logic issue. I did try the usual power cycle everything and reset the inverter settings but no luck getting the battery capacity to read on pylontech mode. I am not sure if there is some broken logic in switching protocols, or if something else about the recent updates to the inverter and bms broke it. I would be curious if anyone else can keep a close eye on the battery capacity when they make the switch and report back.
